Wiring diagram for 69 volt golf car using 5 12 volt batteries
  • 5 more comments
  • larry244jenk Apr 03, 2011
    where are the wires for the center battery in the row of three. I see wire on all the others but not on this one?
    Where are the wires on the center battery in the row of three? I see wires on all the others.
    I still want to know where the + wire and the = wire go to on the center battery in the row of three. I ask for a diagram showing how to wire 5 12 volt batteries to get 60 volts, in this case I see four wired and one with wires that go nowhere. :Lets complete the diagram please.
    Joe, there is not much in my cart that has not been changed out to aftermarket parts. The controller is 650 volt. the coil and f/r switch are extra heavy duty, motor has been modified so that I have a extra f/s switch that is wired to the motor so that I have a torque setting and a high speed setting.. The 12 volt batteries I have to install are for a power wheel chair. they are GEL cell batteries and are totally sealed. 5 or these batteries take up the space of 3 of the standard 6 volt battery. I could bump the voltage to 72 but I thought I would try 60 first.
    Joe, my cart has been modified to include the motor , rewired to handle higher voltage and is two speed thru a extra heavy duty forward/reverse switch, one setting is for low speed torque and the other setting is for speed. the controller is 650 volt and both the coil and f/r switch have been changed out to a very heavy duty version. The batteries I have are 12 volt Gel Cell that are used in electric wheel chairs and etc. they take up very little space. I could just jump to 72 volt but I thought I would play around a 60 volt first. Just trying to get some help getting the batteries wired for 60 volt.
  • larry244jenk Apr 04, 2011
    VERY HELPFUL, PROVIDED JUST WHAT I WAS LOOKING FOR.
    Thank you very much, after i enlarged it I could see the lines that I could not see in the smaller version. Problem Resolved.
  • 1,940 Answers
Here are the wiring diagrams for 5 12-Volt Batteries wired in Parallel and in Series:
Posted on Apr 03, 2011
  • Jeremy Moore
    Jeremy Moore Apr 03, 2011
    The 5 12 Volt Batteries Wired in Series has a Main Positive Cable connecting to the first batteries positive terminal. From the First battery, connect a short cable from the Negative Terminal of the current battery to the Positive Terminal of the next battery in line. At the end of the line, you will have a Negative Terminal left. This is your Main Negative Cable Terminal.
  • Jeremy Moore
    Click on the diagram to download a larger version of the diagram. It is complete, I assure you.
    President:
  • 2,080 Answers
Most golf carts normally use a six pack of 6 Volt batteries connected in series to a 36V motor.
The batteries are usually 6 Volts each and when they are connected in SERIES, add up to the required 36 Volts total.
Here is a link to a diagram depicting the standard layout of six - 6 Volt batteries in series.
http://www.google.ca/imgres?imgurl=http://www.cartaholics.com/tech/other/MarketeerBatteryBoxWiringDiagram_36V.jpg&imgrefurl=http://cartaholics.com/forum/lofiversion/index.php/t2524.html&usg=__MxzJ5twWIc7s0Pc_T8c5UQZ26Ho=&h=465&w=715&sz=50&hl=en&start=0&zoom=1&tbnid=wmU3mFRqFg22mM:&tbnh=146&tbnw=224&ei=jLuYTYrkE4XItweLrdXyCw&prev=/images%3Fq%3Dgolf%2Bcart%2Bbattery%2Bdiagram%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1001%26bih%3D589%26tbs%3Disch:1&um=1&itbs=1&iact=hc&vpx=289&vpy=90&dur=828&hovh=181&hovw=279&tx=181&ty=103&oei=jLuYTYrkE4XItweLrdXyCw&page=1&ndsp=12&ved=1t:429,r:1,s:0
Could you please comment back here to this page with the model number of your machine and I will be able to provide more detailed information specific to your model.
Thank you very much.
Joe.
  • Joe2
    Joe2 Apr 03, 2011
    Hehe, ok. I guess you have a real hotrod there.
    As long as you are certain the motor you are using is rated for the higher voltage, then you can still use the same setup as in the diagram I provided.
    Five 12 Volt batteries in series will give you your 60+ Volts DC. Just leave one of the batteries in the diagram out. The wiring will still all run from the positive pole of one battery to the negative pole of the next in the series. The remaining leads from the batteries on each end of the string will be your main 60 Volt positive and negative supply terminals.
    Just make sure if you need a 12 volt feed for instruments and guages and such, that you only take the feed off of a single battery unlike the diagram which shows the feed coming from 2 in series in order to make the 12 volts.
    Otherwise, just make sure you use heavy guage wire to connect them all and be extra careful, you are starting to tangle with some serious current.
    I noticed you added your last comments twice.
    Make sure you click on the VIEW MORE COMMENTS AND CLARIFICATIONS buttons to see the full list of the latest comments (including your own) that normally remain hidden at first.
    Don't worry you are not the first to miss that feature, it happens all the time.
    Good luck. Let me know if you need anything else and I will help you out as much as I can.
    Joe.
I have a ezgo 36 it's got power but runs slow, batteries are full
Does your controller have a 6 pin connector on the top? If it does then only 4 pins are wired. Pins 1 and 2 are the throttle, pin 3 is reverse and pin 4 activates the controller.
First I would check the batteries under load. then check voltage from main negative battery post to pins 3 and 4. Should get approx. 15 volts going to the ITS throttle and other pin should get 5 volts at full throttle. If you get no voltage at either pin then probably a bad controller. Go to buggiesgonewild.com and search for wiring diagrams, they have a few for download.
Aug 14, 2015 | EZGO TXT Golf Cart Golf
Wiring diagram for EZ-GO Marathon 36 volt golf cart
Excellent......asking for a Golf Cart wiring diagram in a Water Heater posting board....
Works for me
I have a Westinghouse Nuclear Reactor I bought used from the USN. Can you tell me where I buy the Heavy Water for it????? Kroger? Safeway? Whole Foods?
Oct 20, 2014 | Water Heaters
How to wire a 12volt lights to a 36 volt system on an E-Z-Go golf cart
all you have to do is run the positive wire from the lights to the positive post of one battery and the negative wire to the negative post of the same battery. You will be using just one battery to power your lights. Hope this helps
Oct 19, 2010 | MK Battery Golf Cart 12 Volt Sealed Gel...
Fazer nash electric vehicles 72 volt golf carts
bad batteries?? maybe only getting so much power then ooomph hmm bad connection maybe to battery
Apr 09, 2010 | Health & Beauty
Wiring diagram and user-owner manual, fraser nash
need wiring diagram
ultra multi mode meter plus
Apr 17, 2009 | Electronics - Others
Free wireing diagram on a 1987 DS Electric golf cart
I have 1987 club car golf cart. I need the battery wire diagram.
Jan 01, 2009 | Electronics - Others
Wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Radio installation in a golf cart
Each battery is 6 volts. You would have to connect to the 1st Battery 12 volts posiltive {+} side and the 3rd battery negative side[-]. Run the positive lead thru an inline 10 amp fuse , then to the radio.
Jul 22, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
