Question about Vacuums
How replace belt CB-1 (also called belt CB-3) on my Kenmore cb-3? Thank you. Bruce Byrolly bruce.byrolly@comcast.net h 410 901-9977
  • bruce_byroll Apr 05, 2011
    I haven't tried to use it yet.
    Bruce Byrolly
    April 4, 2011
    Bruce Byrolly
    April 4, 2011
  • 8,197 Answers
May I get the model # of the vacuum to help you more it should be something like 116.25512506. If that is the model # then go to the link below page 16 will tell you how to change the belt.
http://www.managemylife.com/mmh/owner_manuals/4871/KENMORE-Vacuum-Canister-L0412323?brand_name_search=116.25512506
Posted on Apr 03, 2011
Is the sears kenmore model 116.59319211 beltless
No, the head unit takes a CB-3 belt
Jul 27, 2015 | Kenmore Vacuums
What sort of switch can I replace it with?
Bruce, if you are talking about a vacuum cleaner, you want an exact replacement switch. They're not too costly.
Oct 29, 2012 | Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
Can you use steamer on Bruce pre-finished hard wood floors ?
its not advisable to use any type of steamer such as the one you have on any hardwood floor unless it is a SEALED floor.
Good luck.
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have the bagless hoover windtunnel and it doesn't pick up anything and it is very hard to push. Changed the belt and The rollers are spinning and the filter has been changed. What else can I do?
It sounds like there are dirt and hair wound around the wheel axels cousing them not to spin freely. You have to remove all hair and carpet fiber. Then drop a drop of lubricant oil on the axel.
Change the filter.
You should even Check the floor nozzle for clogged dirt.
BR
Bruce
Aug 27, 2010 | Hoover U6630-900 WindTunnel Bagless...
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Trying to find the schematic or repair manual.
I did not open my NEW Bissell powersteamer PRO for a year after purchase. There were NO instructions or manual. Solution...Take every box apart before leaving Sears.
Jul 31, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Aerus electrolux CB 2000
I e-mailed Aerus about my old Model CB unit, (around 40 years old, looks like a chrome and red shop vac) and, unfortunately, they no longer make parts for it and I decided to retrofit my old Shop Vac 5-8 Gallon bags to it and they seem to work. However, probably better to find a ring and gasket from a vacuum place that was known to sell them or ask the nearest vac stores, like the other fellow said to get some information. The old canvas filters I would think were more or less motor protection barriers just in case something gets sucked into the intake. By the way, I have seen the occasional CB units on eBay and other sites, and, the 2000 looks a bit like mine only in modern plastic as opposed to metal (apparently different colours).
Jan 16, 2008 | Vacuums
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
