Question about Coleman Hot Water On Demand
New battery.no ignition no sparking noise nothing at all
  • m_s_drew Apr 06, 2011
    Thank you .It you happened to be the fuse inside the circuit board had blown ,this then gave me the ignition spark back.Then to find the pump was broken as well.
  • Grant Watson Oct 17, 2012
    I had the same problem with my unit. I worked out it was the fuse on the main board. This had blown due to the pump being seized and drawing too much power.
  • 3,740 Answers
There is a flow demand sensor in the tubing that must be able to sense water flow or nothing will happen. If there is debris in the sensor.... then it will not light. Also is the pump running at all? If the pump is not running check the wires at the battery connector to see if there is a broken or improperly connected terminal. Lastly make sure the propane bottle is properly installed.
I recommend you attempt this:
You can back flow the heater by disconnecting the pump / and placing / gripping a plastic bag with about 1 qt of water over the outlet hose. Then siphon water backward through the heater to clear any debris introduced via the pump. (Been there done this.)
If this does not work feel free to seek another Expert. Just passing on my personal experience with this heater.
Thanks for choosing FixYa,
Kelly
Posted on Apr 04, 2011
Car wont start
replace fuel filter.listen for fuel pump operation with ignition switch on position for 3 seconds should hear fuel pump running should have humming or churling noise if so fuel pump working if hear no noise fuel pump faulty or could have blowed fuel pump fuse or bad relay.if fuel system okay problem could be ignition timing off due to worn broken timing belt.could have faulty ignition module.bad crankshaft sensor or camshaft sensor best to have vechicle code scan first before buying alot of new parts.could have bad ECM. many things will cause no start problems i.dont know model type vechicle.could have bad spark plugs wires. distributor cap and rotor could be bad.ignition coil could be bad.
Mar 28, 2013 | Cars & Trucks
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
2003 chevorlet impala does not start
if security light flashes you need to take to a dealer and have a new ignition switch installed or programmed. try another key first.
Sep 14, 2012 | 2003 Chevrolet Impala
No electrical power
you might have burned out the new switch
Mar 30, 2012 | Garden
2001 sportster no spark
Hi Anonymous, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below and good luck.
Harley Davidson Sportster error codes and how to access them
Mar 29, 2012 | 2001 Harley Davidson XL 1200 C Sportster...
My Perfect Flame E3520-NG won't light and I can't find support or a manual for it anywhere. I replaced the battery but still get no sparks.
There are a few things you can check.
If the igniter makes the noise like it is trying to spark then you may have a short in the igniter wire or a crack in the electrode. Also, the gap between the electrode and the igniter box may need to be adjusted to get a stronger spark.
If the ignitor doesn't make noise, it could be faulty and need to be replaced. Battery igniters are very prone to wearing out prematurely. Sometimes they can be replaced with a more reliable piezo igniter.
Mar 03, 2010 | Grilling
Coleman Hot Water On Demand Logo
1,630 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
