I have a 40 inch lcd tv (sony bravia).there is lot of power fluctuation in my locality.should i use a voltage stabilizer for my tv or not.if yes then which stabilizer should i use. thanks.
SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
Posted on Apr 27, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Posted on Oct 01, 2009
rulds2008
  • 3866 Answers
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Posted on Nov 30, 2009
Testimonial: "i just hope this works"
  • 2386 Answers
SOURCE: Is Sony BRAVIA EX 500 Series 40-Inch LCD TV good
According to user rating it is very good product, you can also view the rating here
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10151&catalogId=10551&langId=-1&productId=8198552921666077654
good luck, do rate the solution if got help
Posted on Dec 07, 2010
SOURCE: Voltage Stabilizer for LCD TV
Samsung 32 inch LCD TV needs a stabilizer support or not? Can any expert answer?
Posted on Mar 21, 2011
My Sony Bravia LCD TV will not turn on.
If no voltages,then replace all main capacitors,power ic and optoisolater ic,do not forget the rectifire diodes/bridge and the output diodes.
Nov 25, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
How do I repair the Sony Bravia LCD HDTV?
Hi... If it is a power board problem it is most likely capacitors that fail. Look for any electrolytic capacitors that are bulging on top. They are normally round with an aluminium top with a cross marked in the metal. They fail over time if they are low quality or high ESR with high transient voltages.
Make sure that you replace them with same or higher voltage ratings but with the same capacitance.
If you do buy them for stock in your repair shop look for high quality low ESR variety that will not a cause comebacks.
Hope this helps!
Feb 16, 2015 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Voltage stabilizers required for 32 inch LCD tv
Please clarify by what you mean "voltage stabilizers".
Do you mean the power supply module?
Try EBAY, or www.shopjimmy.com
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 19, 2011 | Sony 32 KDL32BX320 32 LCD TV
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Feb 19, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Apr 27, 2008 | Sony BRAVIA KDL-40V3000 Television
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
