Question about Toshiba Satellite A135-S4527 Notebook
Toshiba satelite laptop mouse not working
My laptop mouse not working...msg.shows go to device setting...in device setting lots off points there...what to select...presently working with external mouse....mail solution to me if u can....to pushpendra_mehta @yahoo.co.in ...thanks.
  • pushpendra_m Aug 15, 2008
    solution not useful..no button on touchpad....so cantdo anything...mouse not working still....
  • sunnxx Jan 09, 2009
    I have the same problem. I was on my laptop the night before, i turned it off normally, then went to bed. When i woke up the next morning it was on the log in screen and the plug-in mouse, and the touch pad would not work!! I couldn't even turn it off...
    Scholar:
  • 46 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} So in regards to the touchpad, it’s not working. Device Manager is where you want to go to see if something is wrong with it. You know also, I'm not sure if any other Toshiba has this built in it. Like on some HP, they have a button just to the top of the touchpad. If you hit it, it turns off the touchpad. Hit it again, its back on.
I’m pretty it doesn’t. If the button is not there, then it might be just your touchpad is dead or loose cable on the inside.
Let me know
comier957
Posted on Aug 10, 2008
  • Anonymous Aug 16, 2008
    Have you try to reinstall the mouse drivers. Go to this website.
    http://www.csd.toshiba.com/cgi-bin/tais/...
    This is where you can select your model for your laptop.
    It's also where you can downloads the drivers for it, once you have select the model.
    Also send me a screenshot of your device manager. That way I can see what's not install. Send me a screenshot of the mouse error you getting if not in the device manager.
    I can make a better solution or choice this way.
    Let me know
    comier957
SOURCE:
How do I get the pinch and zoom to work on Toshiba satelite
Open the "Control Panel" Then change from "Category" in the upper right of the screen to "Large icons". Then find the "Mouse" icon. From there you can change settings for everything related to your mouse.
Jul 23, 2014 | Toshiba Satellite Computers & Internet
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Hi my mouse in toshiuba a30-391 satelite is working for the first minute or so than after impossible to use checked the drivers and settings and everything looks ok please help
Hi
i would go to device manager
scroll down to find mice and other pointing devices or the touchpad
un install it
then restart the laptop
hopefully window will then find new hardware and re install it correctly for you
hope this has helped you
Mar 08, 2011 | Computers & Internet
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
External mouse not recognized
Go in device manager and uninstall the usb root hub one by one and then restart the machine twice then check wether it is working or not.
Jan 18, 2009 | Toshiba Satellite A135-S2276 Notebook
Synaptics touchpad totally dead no response!
Right click the Synaptics Pointing Device and select Pointing device properties OR double click the Synaptics Pointing Device. A Mouse Properties Dialogue is displayed, then select the Device Setting Tab and then select the synaptics device under device section then select the enable button and lasting select the the Apply button.
Jul 08, 2008 | Computers & Internet
I have toshiba notebook A200.I have been using a USB mouse,and I now can not get the touch pad to operate.Plerase advise me what I can do.I have tried FL F9 to no avail.
If you unplug the mouse and then start up the machine does the touchpad not work at that point?
Some systems have a settings in BIOS that prevent the touchpad from working if a mouse if connected.
Try unplugging, start up and if the touchpad doesn't work, shut down and go into the system settings and turn on the touchpad (if turned off).
Also, make sure the device manager doesn't show any Yellow Exclamation points, meaning a bad or missing driver. To get to Device Mananger, go to control panel, system, hardware, device manager (in Windows XP that is).
Jun 01, 2008 | Toshiba Computers & Internet
Toshiba satelite M200 touch pad not work
saket,
try to find out if there is any button for you touchpad on the keyboard, if you found then press this and try.
If you did not find then try the following:
  • Goto Start -> Control Panel
  • Double click on mouse icon
  • Then goto Device setting, there you can find an option/button to make your touch-pad enabled/disabled. Make it enable and try.
Thanks
Iqbal
Apr 28, 2008 | Computers & Internet
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Mouse pad
I have this problem every now and then. For a quick fix, I goto the toolbar next to the time where it has the Synaptis Pointing Device Icon, a box, with two boxs under it (like the mouse on the laptop) left click it -> Pointing Device Properties -> Device Settings Tab, highlight the device and click DISABLE, it'll ask if you are sure you want t disable it -> OK. Then simply, click it again, and ENABLE. This like, "resets" the mouse, mine works everytime.
Sep 30, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
3,308 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
