Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
We have the 3 phone with answ.dnd, etc. Our 3rd phone was accidently left unplugged during a computer repair. It has been about 4 wks now and the phone is dead. I tried it on the main craddle - still blank; I have tried taking the battery out and replacing it - all to no avail.! HELP!!
  • 2,382 Answers
Hi, the phone uses inductive charging because of the waterproof feature. I suggest that you remove the battery cover from the back of the handset, unplug the battery, and then plug it back into the handset.
If it still doesn't power up, then the phone needs to be service by dismantling and cleaning the battery house and some other component due to battery discharge...
Posted on Apr 03, 2011
How do i change the time on my phone
Try this: • PRESS PROGRAM • DIAL ** • DIAL 1234 (SYSTEM PASSWORD) • DIAL 000 (DATE AND TIME PROGRAM NUMBER) • PRESS THE NEXT KEY • ENTER THE YEAR • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL DESIRED MONTH IS DISPLAYED • PRESS THE ARROW (FWD/DND) KEY • ENTER THE DAY OF THE MONTH • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL THE CORRECT DAY OF THE WEEK IS DISPLAYED • PRESS THE STORE KEY • PRESS THE NEXT KEY • ENTER THE HOUR • PRESS THE ARROW (FWD/DND) KEY • ENTER THE MINUTES • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR AM OR PM • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR A 12 OR 24 HOUR CLOCK • PRESS THE STORE KEY • PRESS THE END (HOLD) KEY • PRESS THE PROGRAM KEY TO EXIT PROGRAMMING
If this helps you, please rate. Thank you
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Phone automatically keeps reverting back to do not disturb
The feature should't reset itsself after you enter feature #85 (or press the DND button again). A co-worker isn't accidently turning it on are they?
You might also check if the DND button (if programmed on the set) is stuck down.
Sep 28, 2009 | NorStar M7310 Corded Phone
Phone is displaying DND (do not disturb)
Do not pick up the receiver press feature button dial 60 press feature button again, at least this worked for me.
Mar 17, 2009 | NEC DTU-32D-2 Corded Phone
Comdial 7260-00 can't turn off dnd
It turns off the same way you set it :-)
Go to the idle phone and press #4. It's a toggle so if you do it again it will reset DND. There's also a FEATURE 4 command for one-time DND.
Here's a link to the DX-80 user's guide. http://public.carl.airpost.net/Phones/DX80-DETUG.pdf
Carl
Jan 28, 2009 | Comdial 8324S-PT Corded Phone
Cisco ip phone 7940 does not ring for incoming calls.
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Jan 27, 2009 | Cisco 7940 IP Phone
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Do Not ring During Meeting
DND (do not disturb) is the only easy way I know of doing this for a short period.
If you do not have a button programmed for DND you can press [FEATURE] 85 to turn DND on or off.
Feb 25, 2008 | Nortel Meridian M7208 Corded Phone
GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Feb 22, 2008 | Lands Phones
No ringer
I would suggest unplugging the phone from power and the phone jack for about 5 minutes and see if that will clear the DND LED.
Here is a link to the manual.
http://www.wedophones.com/Manuals/Aastra/IBM-412CID%20Four%20Line%20Phone%20User%20Guide.pdf
Please refer to Pg 38 specifically for disabling DND.
Thanks
Dec 05, 2007 | IBM Corded Phone IBM412CID
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
24 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
