Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
In the last few months (5 yr old machine) the dryer takes forever to dry normal loads. I usually have to run it twice to get permanent press type clothing dry. Is this normal wear on the machine, or is there something I should look for?
  • Whirlpool Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Apr 03, 2011
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
My Bosch dryer never seems to get very warm.It's an Axxis. I've only washed about 10 loads. It seems to take a long time, and when I take the clothes out, they are cool to the touch. Even when I touch the...
There are a few possibilities here:
1. Washer/dryers generally take longer to dry clothes than a stand-alone dryer so if you previously had a stand-alone and are now using a combi, this could be the reason.
2. There are usually at least 2 heat settings on a dryer, so maybe you have it on a cool setting?
3. The last part of a drying cycle (5-10 minutes) is usually cool - even when on a high setting. This helps to reduce creasing and cools metal parts such as zips and buckles for saftey. This could explain why everything feels cool when you remove the clothes.
It's possible your old dryer didn't have the cool final setting and/or it was higher power than your new Bosch and therefore dried the clothes quicker.
If your new machine is taking an eternity and your clothes still aren't properly dry, then there may be a fault with your dryer thermostat which is switching the heating coil/element off at too low a temperature. However, I suspect your problem is related to information I've written above.
It would help to know whether you have an Axxis washer/dryer or just a dryer. If the information above doesn't help you to solve your problem, please post back with details of your machine, including the model number, if possible.
Regards,
BElectric.
Nov 25, 2010 | Bosch Dryers
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Our dryer takes FOREVER to dry. Over an hour and a half for permanent press???? I am always a wet load behind. We have cleaned out vents. The dryer does get hot.
Is the dryer vented properly to the outside? Feel the amount of air flow when it's running and empty. It should be substantial. If it feels weak, you need to take the back off the machine. There is a metal 'box' that is connected to your vent line going out. Take the cover off the 'box and it is probably full of lint. This blocks the exit air and causes your problem.
Jul 01, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Clothes not drying completely, still damp when taken out.
the heating element has probably blown a coil or your thermostat is broken
Apr 26, 2009 | Whirlpool LER4634J Electric Dryer
My dryer takes forever to dry clothes!
it could be the vent pipe is clogged. check that out too
Jul 05, 2017 | Maytag Dryers
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer not drying completely
Sounds like your heater element is going out.
Dec 06, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
132 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
