Question about Sport & Outdoor - Others
I need a few condenser wico-x9327 and x11362 and x5463. 9327 from a 12hp, 11362 25hp. thank you; david wilson- the puget sounders!
The screen
leadbetters full of hot gas-its all in the supination of the wrist-cheers Denny p s shawn clemms and paul wilson you tube-my men!
Sep 17, 2013 | Correct Grip LLC Womens David Leadbetter...
My sounder does not work
Hello Mr Wilson,
I have looked into this for you. There could be several things that can cause this, recent updates needed, Battery, etc.... So, instead of guess work, What I am doing is giving you (In case you don't have it) the owners complete manual with trouble shooting etc.... And some other links for support and numbers etc.... I hope this helps, but like i said there are several things that could cause this. My guess is battery possible and or updates. Please check out the manual and links I have posted. Thanks So Much Mike, Please if you can rate accordingly for my free help. Also I am putting my link at bottom for my personal Page of services I offer. Thanks Again, Mike
http://store.humminbird.com/media/document/587_597_HD_DI_Manual.pdf
http://store.humminbird.com/products/399598/587ci_HD_Combo
http://beta.fixya.com/users/mc1beanThank You!!
Oct 22, 2011 | Humminbird 2009 587ci Gps/fishfinder...
Hi, I have bought the Alcatel Versatis D300 Duo cordless phone. On the outside of the box it listed the key features of the phone in French and in English. When I got home and unpacked the box I found...
Fixya would not be able to supply the instructions. Try Googling (alcatel)(D300)(manual) without parens. You may find what you need available from some obscure source.
May 26, 2017 | Lands Phones
I need a wiring diagram for a simrad qx44 sounder
simrad nse 12 with bsm 1 sounder does it need its own power or does it get it from the starter pack thanks richard
May 28, 2010 | Simrad CX33-E WAAS/CP/FF 4012150700 No...
Need coil, points and condenser for Homelite EZ chainsaw
The E used 2 different brands, WICO and Phalon.You might try an antique saw dealer or a general search on Goggle, but know what brand you have, you cant mix the parts
Nov 17, 2009 | Homelite Garden
Sincgars system in 92F configuration, no sidetone in VIC-3 headse
check the wiring of the antenna ... i had the same problem a few days ago and it was that
mike@bvsigns.com
Aug 31, 2009 | Electronics - Others
IGNITION PROBLEM
You may have a difficult time finding those. I would go to the local mower shop and get an electronic ignition module and replace it with that. It will probably cost less than the points and condenser and make the saw more reliable too.
Please rate if this helps-
Mar 27, 2009 | Homelite Garden
GPSMAP 235 Sounder
Some 235s had a problem with the contrast setting. When the contrast is set to full the screen turns black.
When you turn on the GPS and the screen goes black, try tapping the left arrow on the track pad a few times. You should see the screen start to lighten. If that doesn't work, tap the power key and try tapping the left arrow a few times.
May 17, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
