Question about Electrolux Washing Machines
Door on front loader washing machine EWF1495 - Electrolux Washing Machines
  • patlind77 Apr 03, 2011
    after running various wash cyclies the door want unlock and I can't get the clothes out. The light on the door goes out and unlock is displayed. Is there a manual way of opening the door
  • Electrolux Master
  • 19,396 Answers
Hi.
If there is water inside the machine the door will not unlock.
Access the drain pump filter and remove water from there. Electrolux front loaders have an access door at the bottom of the front side, on the right hand bottom corner. Disconnect power from appliance, open the access door, then unscrew the pump housing cap. Be ready with containers, you will need to collect the water.
After removing water and blockage, reapply power and start the machine.
If that does not work, then there is a defective part. In that case the lock can be accessed, either from pump filter housing, or more comfortably from the top, removing the top panel. In that case call Electrolux, you may need a technician.
Start removing water from pump, that will usually fix the problem. If that does not work, check also the drain hose at the back, if hose height or elbow setting is incorrect you will get water from drain getting back inside the tub, and machine does not open.
Regards.
Ginko
Posted on Apr 03, 2011
  • 8,197 Answers
MAy I ask what is wrong with the door or can you please explain the problem a little more
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Front loader washing machine door won't open
try unplugging the machine to reset it.
Feb 27, 2012 | Samsung Washing Machines
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
Kenmore elliet washing machine, front loader
To open the door manually:
UNPLUG the machine...
Remove the toekick panel (way down at the bottom).
Feeling along the inside of the front panel. You should be able to find a tab shaped like a teardrop attached to the door latch unit.
Pull the tab down just a little bit ... gently ... until the door opens (or you hear the latch click - then try to open the door).
Is the machine displaying a code?
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Oct 05, 2008 | Washing Machines
Zanussi Front loader washing machine
is the door loose( up/down movement) could be hinge problem,or the door lock may need replacing.
Mar 20, 2008 | Washing Machines
Washing Machines Logo
132 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
