The "open with" box always
    Sergeant:
  • 267 Answers
"Open With" box concerns when Windows can not find any linked programs with that file extension. But you have stated that you are unable to execute the .exe files also. I think you have installed MS-Office on your computer and still you are unable to run that application in any way. This indicated that your system files have been corrupted due to acute virus infection. The only way to get rid of this trouble is to repair your Operating System (if possible) or to go for a direct re-installation of your OS(formatting) and use a recommended anti-virus after a clean-format for whole future. If and only if you are using Genuine Windows, I recommend you to use Microsoft Security Essentials as anti-virus, otherwise, go for any custom anti-viruse available in the market. You can use McAfee or NOD32 or Norton as antiviruses. But as the free anti-viruses are concerned, you can use AVG or Avast, whichever you like the most. But I recommend you to use AVG personally.
Download these antiviruses from below by clicking over the links:
  1. Microsoft Security Essentials
  2. AVG
You can download the 64 bit version by scrolling to bottom of the page.
Let me know if this helped you in any way,
Hope this helps,
Mrityunjay.
Posted on Apr 03, 2011
Whenever I try to download and open a new program, the computer asks me to choose a program to open it with.
Hi golfnutz
Usually a file is opened by a program that specifically handles that kind of file, for example MS word opens (amongst others) .doc files and .rtf files MS Excel opens .xls and .xlsx files.
A downloaded program would normally need to be installed before you can use it, if the program files are in a compressed format then they will need to be extracted before they can be installed.
Try right clicking on the files and if the menu that opens includes the option to extract all then select that.
You should be able to tell what sort of file you are trying to open by looking at the file extension, program files usually end with the extension .exe.
Sep 15, 2014 | HP Pavilion Computers & Internet
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
PROBLEM OPENING MS WORD: This might be a backwards
Uncle, you found a great workaround to fix this problem. If you would like a more permement solution, try the one below. I found this answer here: http://windowssecrets.com/forums/showthread.php/136470-Word-2007-ERROR-quot-There-was-a-problem-sending-the-command-to-the-program-quot
It sounds as though the DDE setting for the .doc and/or .docx extensions are broken.
You might want to "re-register" Word's file extensions, which simply involves using the /r startup switch. This article provides more than anyone really needs to know: How to use startup command line switches to start Word 2010, Word 2007, Word 2003, Word 2002, and Word 2000. In brief:
Close Word
Start > Run > winword.exe /r {ENTER}
Does that fix it?
If you want to try manual surgery and are running Windows XP, you can view/edit the setting from Windows Explorer or My Computer: Tools > Folder Options > File Types tab > [appropriate extension] > select open then edit or modify. If you uncheck the "Use DDE" box and save, then the registry should be updated.
Oct 04, 2013 | Microsoft Word for PC
Hi, I've just installed Microsoft Office Publisher 2010 on my PC (Vista Basic). It works fine and everything. However the saved publisher files have icons like blank pages and won't open automatically...
Hello:
You can manually locate Microsoft Publisher when going to the "open with" dialog. Follow the steps below:
  1. Right click on a Publisher file.
  2. Choose "Open With..."
  3. Choose "Choose Default Program..."
  4. A dialog box will open. There is a list of programs at the top.
  5. Near the bottom of the dialog box, there should be a link that says "Browse..." Click it.
  6. You need to locate the Microsoft Publisher Program. For Office 2010, it should be at:
x86: C:\Program Files\Microsoft Office\Office 14\MSPUB.exe
x64: C:\Program FIles (x86)\Microsoft Office\Office 14\MSPUB.exe
7. Click once on the file and choose "Open" 8. Check the box called "Always use the selected program to open this kind of file" 9. Confirm your selections and click "OK" at the bottom of the dialog box.
Jan 27, 2011 | Microsoft Office Professional 2010
I have Canon Lide 60 Scanner. I have to use OCR function to convert printed text to MS Word 2007. I click "OCR" on CanoScan Toolbox, select Black and White (OCR) Scan Mode. Then, it gives me...
Hello
you are doing well, just select MS word program Exe file in C:\program file\Microsoft office\officexx\winword.exe in set option of canoscan.
Then your scan will open in MS Word
Hope it will helps and do rate the solution if so
Dec 21, 2010 | Canon CanoScan LiDE 60
All my word files are opening in other formats plz help
in this case do a right click on the file then click on open with and then clickon choose program
select ms word from there and make sure that the option ALWAYS USE THIS PROGRAM FOR THSI KIND OF FILE should be checked
OR
if that doesn't work try
open my compputer the clcik on tools - folder options - file types
look for DOC click on advanced the highlight open then click edit
make sure in application used to perform action thsi shold be written
"C:\Program Files\Microsoft Office\Office12\WINWORD.EXE" /n /dde
check use DDE
below that type
[REM _DDE_Direct][FileOpen("%1")]
application
winword
topic
system
Do the same with DOCX
thanks
Mar 03, 2010 | Microsoft Office Word 2003 for PC
Ms office 2003
Generally  this error occurs because you have deleted your word.exe & excel.exe files to confirm of deletion of these application file you can check by following pathway.  If they are not there means you should restore deleted file from Recycle Bin.
      "C:\Program Files\Microsoft Office\OFFICE11
If the file are not available in Recycle Bin then you should reinstall M.S. Office Application.
Or
You can restore your system to an earlier date when it was working prpoperly.
Jan 13, 2009 | Microsoft Office Professional 2007 Full...
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
Windows vista errors
Better to install MS Office 2007 or Office XP.
Note:Before Installing new office software,please remove old one.
Feb 25, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
