Question about Whirlpool WED5300S Electric Dryer
Doesn't get warm or hot - Whirlpool WED5300S Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 03, 2011
Admiral atw4675yq doesn't dispense warm water
Guest,
So I was lucky enough to buy the extended warranty with your same unit and when I noticed the same issue, I called the technician.
What he tells me is that this time of year, city water is too warm to require the addition of hot (71 degrees as read at the flow). Apparently to meet the Energy Star requirement, the temperatures were lowered from what they used to be.
He suggested that I wait until Dec/Jan until my cold water temp gets into the 60s and then listen for the hot to kick in intermittently.
From what I have read on the web from other customers of various other makes and models, this problem does not seem to be restricted to Admiral.
Hope that helps. Take care and have a good day.
Mar 14, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
My Oster wafflemaker doesn't get hot! The lights are on but only gets warm
One or more of the heating elements are not activating. If you take it apart, perhaps you can do a continuity test on each element to see which is bad. I don't believe they sell element replacements so your only choice would be a new purchase or warranty.
Jan 29, 2013 | Kitchen Appliances - Others
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
Jul 21, 2012 | Ovens
I have a 96 chev. caprice classic and the a/c doesn't work it just blows hot to warm air what is the problem?
Most common low on freon,or the low pressure cycling switch,If its beacuse its low you should fix the leak and refill.
Mar 21, 2012 | 1996 Chevrolet Caprice Classic
2000 malibu runs hot if not warmed up
How do you know it gets hot? Are you going by the temperature gauge on the dash? Or have you checked under the hood and found out the engine really is running hot? ...Reason I ask is, something just doesn't sound right in your description. After just 5 minutes from starting and driving away, the engine would not yet be at normal operating temperature. That would explain the heater not yet warm. But the temp. gauge says hot?
If so, I would replace the temperature sending unit on the engine. the one for the dash gauge, and see if that was the problem-not reading the temp. accurately.
Couple of other things: Are you sure you got all the air out of the coolant system? Start the car with the radiator cap off and let it run until the engine is warmed up fully, then shut it off and install the cap. Does your reservoir tank stay about half full where it should be, between the full-hot and full-cold marks?
If your problem persists. I would have the coolant system pressure tested, and see if you could get a true temperature reading of the coolant when it seems to be running hot.
Good luck.
Mar 05, 2012 | Cars & Trucks
2002 E350 still overheating? New Thermostat, and new spark plugs. Drained & Flushed cooling system - radiator not blocked. No leak from water pump. Catalytic converter became red hot once while reving...
With the vehicle cool, remove the radiator cap, and manually pump the lower radiator hose until all the air is out of the system. That is how you get the air out of the system. If it is still overheating from there then you should check the fan to make sure that it is working correctly.
Jun 07, 2011 | 2002 Ford E350
Whirlpool WED5300S Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
