Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer seems to start Ok till about 24 mins remaining. Then it starts to fill,stops briefly agitates briefly, drains briefly and continues to do the same sequence for many minutes but the timer wont go down from 24 minutes. Sometimes when I open the lid and rearrange or move the tub it will continue the cycle; but now it's getting stuck on the timer and won't continue down no matter what I do.
  • 2,382 Answers
Hi,intermitant problems are always difficult to diagnose. In this caes, the number of failures indicate a fault in the control board. I would start by testing the board. You might see a burnt diode or corrosion or the fault might only reveil itself with a volt/ohm meter. Control panel assembly is only $40. At appliancepartspro.com. You will need the part # off the board
Posted on Apr 03, 2011
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
The washer starts to fill normally, then agitates very briefly, stops, and begins to fill again. When watching the water fill, the water level does not rise at all, and if you push the button in to stop...
It sounds like your drain hose is two low. If your drain hose is inserted into a drain pipe try extending the drain pipe to the same hight as the washing machine.
Dec 27, 2009 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Water doesnt pump out to start rinse cycle
Seems the timer is sticking at the drain cycle. Manually move the timer and see if this helps. If this works then the timer is bad.
Jul 05, 2009 | Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
