Question about Canon LASER SHOT LBP 3300 Printer
How to print A5 paper incannon 3300? - Canon LASER SHOT LBP 3300 Printer
    New Friend:
My canon lbp printer 3300, red alarm light is blinking. i am not take any print. what is the problem?
Posted on Sep 20, 2013
  • 41 Answers
Go to printer and faxes, right click, printer preferances, page setup ,size , select A5 then paper source select casste 1. then click ok. Feed the paper through cassete 1. Print ready
Posted on Apr 08, 2011
How do I print on A5 paper on my TX300F?
A5 measures 148 × 210 millimeters or 5.83 × 8.27 inches. In PostScript, its dimensions are rounded off to 420 × 595 points.
You should be able to select A5 size in the Epson software, but above is a small idea of the sizes in case you have to setup manually, once you get it setup correctly then save it as a profile in the Epson software.If you are printing A5 then you need to make sure it is in landscape mode (if you are printing more than 1 page) if it is actual A5 sized paper or Photo paper then make sure gauge is moved on printer to the size of the medium being used.
Feb 25, 2015 | Epson TX300F Series
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Canon MP520 printing on different size paper
Go in printer preference & select the paper at A5 & then print
Aug 09, 2012 | Canon MP520 All-In-One InkJet Photo...
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Will not print on half sheets of paper that we have cut. Wants A5 paper that we do not order. Is there a way to disable the sensor that detects that our paper is not A5?
Hello dmerrifield.
Unfortunately, there is no proper way to do what you suggested. In any paper tray-style printer, sensors must be used to determine the entrance and exit of the paper as it passes through the machine.
Based on basic printer theory-of-operation, the printer would normally just jam and throw a code. The printer, surprisingly enough, detects your paper as A5, which is the closest to the actual paper you are using. That is actually very intelligent for the printer to determine that.
Anyways, you technicially can just tell the printer to print off of A5 paper at all times and that may solve your problem. Just go through the menus in both your printer's control panel and Windows/Mac printer dialogs to make the change.
The only proper way to use custom-half-sized paper is to use a top-loading inkjet printer. Those have no paper-length sensors and will print on literally anything you throw into it.
Good luck in finding your solution. If what I posted helped you, please positively rate my post. If not, please comment to allow me to assist you further.
Thanks.
-Phil Traversa
Aug 18, 2009 | HP P4015X LaserJet Printer with Automatic...
Loading A5 paper into photosmart 8450
your printer is capable of accepting a5, load the paper on a different direction, with the leading edge 5.83" feed first, then properly aligned the side guides to match your paper this will surely work this time, then slect a5 on your printing properties on your pc
cheers
Sep 27, 2008 | HP Photosmart 8450 InkJet Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Canon LASER SHOT LBP 3300 Printer Logo
443 people viewed this question
old marine
old marine
