Question about Sport & Outdoor - Others
In white plastic case, about the size of two 35 mm camera film cans placed on top of each other, with 2 wires into it. This for a motor for a wood splitter
  • 274 Answers
WHAT?
Posted on Apr 03, 2011
  • rpoole1 Apr 03, 2011
    I am looking for a capacitor for a wood splitter. It is a 60uF, 300V made by Dianz. The manufacturer of the splitter does not stock them anymore and I hate to have to get a new splitter just because one little part is worn out.
  • Kelly Comstock
    Kelly Comstock Apr 03, 2011
    Oh i see. Let me check something and ill get back to you
What film does a Pentax Z50P take?
It is designed to use 35 mm film DX coded from 25 through 5000.
Film can be slide film, B&W, and color negative film.
Aug 27, 2015 | Pentax Photography
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
Is it possible to get 35 mm film for camera?
Any camera store will carry 35mm film, color or black&white, transparency or negative. A narrower selection will also be available at many department or drug store, as well as some supermarkets.
Dec 07, 2013 | Minolta Maxxum 7000 35mm SLR Camera
Nikon EM (1979?) When I zoom out with my lens, the picture in the viewfinder is very blurry.
What happens when you turn the focus ring? And just out of curiosity, how are you getting to a 30mm setting on a 35-105mm lens?
Jan 28, 2013 | Nikon EM 35mm SLR Camera
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
I am confused. Is the N 75 an SLR or 35 mm. My daughter needs a 35 mm for a photography course. She has an N 75.
Both. The Nikon N75 is a 35mm SLR camera. 35mm refers to the size of the film the camera uses. SLR (single-lens-reflex) refers to the design of the camera, which uses the same lens for both viewing and photographing, the film sees the same image you see in the viewfinder.
There are other 35mm cameras that are not SLRs. Likewise, there are SLRs that use other sizes of film.
Aug 14, 2010 | Nikon N75 35mm SLR Camera
35 mm, Minolta X700
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
Sep 20, 2008 | Photography
Help me
Most digital SLR cameras take pictures with an aspect ratio of 2 to 3. (This is based on the size of 35 mm film, where the images were 24 x 36 mm, a 2 to 3 ratio.) That is a different ratio than 8 x 10 inches, which is 4 to 5. There is no way to change the aspect ratio in the camera, so you will have to make sure when you're taking pictures that will be printed on 8 x 10 paper, you leave the processor extra area to crop the portion that won't fit in the 8 x 10 frame.
For information, the 8 x 10 picture became popular when many portrait photographers used 4 x 5 large format film cameras, which obviously will fit perfectly in an 8 x 10 frame without cropping.
Mar 22, 2008 | Canon EOS-20D Digital Camera
Minolta X570 35 mm camera
Just pull the rewind knob up. Rewind the film first.
Oct 12, 2007 | Photography
Sport & Outdoor - Others Logo
35 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
