Question about Frigidaire Washing Machines
Loud noise during rinse cycle - Frigidaire Washing Machines
    Brigadier General:
  • 3,917 Answers
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 03, 2011
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Do I need a belt? It stopped spinning during rinse cycle.
IT COULD BE A BROKEN BELT , open front panel and take a look at the bottom , you might need a flashlight for more accurate visual , good luck , AJ
Nov 20, 2009 | Video Game Consoles & Games
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
259 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
