Question about Mitsubishi VS-50501 50" Rear Projection Television
MITSU VS - 50603
My son just moved his 50603 projection TV. It's dead. Checked all 4 fuses and connectors to see if any thing loose. Nothing obvious. It does arc somewhat when you attach the power to the rear board. Capacitor charge?
  • 927 Answers
Good Day, wecalvin;
Suspect fluid on the PCB's.To find suspected liquid on the PCB's, remove the front speaker cover and the small board held on by 5-6 screws. Look at the first 3 to 5" on the PCB. Use bright light it's not always easy to see. If fluid is spotted remove the boards from the back of TV. Use small brush, like old tooth brush, and acetone. You can get acetone from hardware stores
Look for rusted wires or parts and replace as necessary.
Good Luck, big IRISH.
Posted on Aug 19, 2008
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
NO SOUND OR PICTURE JUST SNOW WAS WORKING FINE THE DAY BEFORE
Check the tv with another cable signal or another tv with that cable signal.Both check,same things happen.Ur tv digital tuner is dead.
Sep 24, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi 50603 no power.
Good Day;
DAVE; Sorry about your problem. .....The TV's board has been damaged by the fluid, causing the PC to have poor/open trace connections. These boards are double trace, circuits top and bottom, so, you have many 'feeds'. You might be able to find some one in your area to repair them. New boards from factory are not available. Some places, factory , will rebuild these boards, it's not an easy fix.
Oct 06, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Won't turn on
Good Day, Check these two areas: 1. CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001. 2). CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB. Good Luck, big IRISH.
Nov 17, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
