Question about Vacuums
I have a hunter fan and my contractor switched the load and green wire in the new zing ear switch. I just need to switch the 2 wires and I can't get the switch open. can anyone help?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
You buy an original replacement for your zing ear switch from this link:
https://www.ceilingfanswitch.com/product/zing-ear-ze-109/
Posted on Jun 24, 2017
  • 710 Answers
I found out that mostly they are connected with fastons. You can get them at hardware or auto parts stores.
From what I've heard Zing Ear switches are a bear when it comes to taking apart or taking off wires.
Good luck.
I hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
I need to replace the fan switch and removed the wiring on the old one before buying the new one not realizing they were not mark on the switch. I need to know which wire goes where?
there should only be 2 wires, and since they are just a pass through switch, One on each side will do,, if the switch works upside down just reverse them
Jul 10, 2011 | Vacuums
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
Hampton bay fan pull chain broke. The electrician took the light kit down and all four wires had come out of the pull switch he could not install replacement switch without knowing which wires went to...
1. Open the switch housing of the fan. This is usually achieved either by removing two screws on the bottom cap of the switch housing, or three screws on the side. Remove the pullchain assembly by unscrewing the brass finial on the outside of the switch housing.
2. Make careful note of which wires attach where to the pullchain. The chain itself will be marked L-1-2-3 or A-B-C-D or similar, the wires will customarily be of different colors, but if not, mark both the wires and pullchain if necessary. MAKE CAREFUL NOTE OF WHICH WIRES ATTACH WHERE. Every fan is different and if you do not make note there will likely be a complicated guessing game. I cannot stress this step enough. Make careful note of which wires attach where to the pullchain. For example:
Black - L, Grey - 1, Brown - 2, Purple - 3.
Some fans may use only two or three wires, some may have a pullchain with two layers and five or more wires. Regardless, make careful note of which wires attach where.
3. Remove the wires from the pullchain. In some cases they may be attached via wire nuts, in which case, remove the wire nuts. However in most fans the wires are inserted directly into the pullchain. Don't make the mistake of cutting them, they can be removed completely by inserting a very small flathead screwdriver into the slot next to each wire. You will notice the ends of the wires are soldered, this is so they will attach to the pullchain.
4. Determine the correct replacement pullchain. This is the tricky part. Many pullchains look alike but in fact switch differently. There are a few factors, first of all, how many speeds does the fan have as controlled by the pullchain? Second of all, how many wires are used to connect the pullchain? These will determine maybe 75% of replacement pullchains. Here are some examples:
- If the fan has three speeds and the pullchain has four wires, it is most commonly a L-1-2-3 pullchain. This is a single pole triple throw switch with an off position. It connects the power from L to 1, 2, or 3 respectively, one for each speed.
- If the fan has three speeds and the pullchain has three wires, it is an L-1-2-1+2 pullchain. This is a single pole double throw switch with an off position and a "both" position. That is to say, in connects power from L to 1 or 2 respectively, and on the third position connects to both. This is the same switch used in many lamps to switch on one bulb (or set of bulbs), the other, or both.
- If the fan has two speeds and the pullchain has three wires, it is most commonly a L-1-2 pullchain. This is a single pole double throw switch with an off position. It connects the power from L to 1 or 2 respectively.
- If the fan has three speeds and the pullchain has more than four wires, there are a handful of different pullchain possibilities however most hardware stores stock the most common replacement. This would customarily be a double pole switch with two layers of wires attaching.
The replacements mentioned above are the most common examples . . . but as I said, there are other switches that may appear identical (for example three speed fan, four wires, but it's NOT the first switch I mentioned). In most cases I would first try the replacement mentioned above. These are the switches that your local hardware store should stock. If the fan does not work with the likely replacement, does not work on all speeds, spins too fast, too slow, etc . . . and you are sure you properly noted which wire connected where on the old pullchain and wired the replacement correctly . . . then it appears your fan is in the 25% that uses a non-standard switch. There are three ways to determine the correct replacement switch:
- Contact the manufacturer. If they are still in business they can theoretically send you the correct replacement switch. If they are no longer in business, contact someone on our forums or other ceiling fan experts, we/they may be aware of the correct replacement for your particular model
- If you can still switch speeds on the old pullchain, use an ohm-meter to check for continuity between the various wires on the various positions. In most cases the important relationships are between L and the various other positions, for example a three speed four wire switch might be L-1-2+3-3. This means in the first position L connects to 1, in the second position L to 2 and 3, in the third position L to 3, fourth position off.
- If you can not operate the switch, you can open up it's plastic casing, either to operate the switch by hand, or to observe the metal bands inside. Some websites that sell replacement switches offer diagrams of the metal bands, by matching your switch up to the diagram you can determine the correct replacement.
5. Ok, you've determined and obtained the correct replacement switch.Seeing as you made careful note of which wires connect to where on the old switch, reconnect the wires in the same manner to the replacement switch. If your old switch did not require the tips of the wires be soldered you may need to do so in order to properly attach them to the pullchain.
6. Reattach the pullchain to the switch housing and replace the finial. Replace the switch housing cap with the two or three screws.
Additional Notes:
I. Fan lights where the pullchain is simply on/off use a two wire pullchain. This pullchain is a very standard on/off switch and it is simply connected to the two wires to which the old pullchain was connected. The wires can be reversed and it will still work. Lights where you can select one bulb, the other bulb, or both use the pullchain mentioned with that example above.
II. Some fans do not use the pullchain to control speeds, but instead have a dial or other control on the fan for speed selection. The pullchain is used to turn the fan off and on, and in some cases also to reverse the fan, select between the high speed and the various low speeds derived from the speed control, or also control the light. In these various examples:
- When the pullchain only switches the fan on and off, it most likely has only two wires and is equivalent to the light kit pullchain mentioned above. It is a basic on/off switch
- When the pullchain reverses the fan or switches the speed control in and out of the circuit, it is most likely the three wire two speed pullchain mentioned above. It is a L-1-2 switch. There are some exceptions such as certain model Fasco fans.
- When the pullchain controls both the fan and light, it is the three wire three speed pullchain mentioned above. It is a L-1-2-1+2 switch.
III. If for whatever reason you do not know which wires connect to which locations on the pullchain, you may yet have some options. For starters, black is almost always L. Some other common color combinations:
For many four wire pullchains:
L - Black, 1 - Grey, 2 - Brown, 3 - Purple
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
L - Black, 1 - Grey, 2 - Brown, 3 - Green
L - Grey, 1 - Yellow, 2 - Purple, 3 - Black
L - White, 1- Black, 2 - Blue, 3 - Yellow
For many three wire pullchains:
L - Black, 1 - Blue, 2 - Red
May 02, 2011 | Vacuums
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
I have a 230 volt pump that needs 2 wires plus a ground wire.What kind of toggle switch will I need for this and how do I wire this?
If there are only two terminals on the motor the only connection would be one leg of the 230 volt supply on one terminal and the other leg on the other terminal.
The switch must be double pole, double throw. That is two terminals on top to connect the two supply wires and two terminals on bottom (that are both open when the switch is OFF and closed when the switch is ON) connect to the only two motor terminals. The ground wire grounds the motor green wire, the switch green screw (terminal) and any green wire on the supply wire.
Mar 10, 2011 | Vacuums
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
westerville5595-now@yahoo.com
Mar 05, 2011 | Vacuums
Hunter Fan Mod 21617-001, wire colors Black with white stripe/ Pink/Yellow/Red/Gray/Black/White. This has a floresent light, no chains or switches. The Pink serves the light. Note the wires are not labeled...
Red and white are twisted together,or however you combine wires.I use plastic wirenuts.Always twist clockwise as the wirenuts are most effective that way and the wires will stay together better.Black/white,yellow,and gray are the speeds yes,and the fan wires go to the receiver wires.It sounds like you do not have the receiver?If it isn't already built in,it should be small enough to fit within the smallest part of the fan base.The remote is the transmitter.Here is a link to show you the wiring.Red&white twist together for house power.Black for house ground.It also shows a THIN WHITE wire for the antenna.It is not necessary to hang it outside of the casing.You should make it spread out around the inside in a full circle,that should be fine.Just not wrapped tightly around the motor,loosely is better.It does show the antenna wire hanging out in the diagram.You can do that also,just make sure it isn't hit by the fan,and it will not cause a fire if pinched by the plate.If you do have all the wires connected,it shows that the dip switches on the receiver must match.Make sure the remote has the battery removed when changing these.When they are correct,there is no way to tell what the fan is set to and it could start moving.The dip switches are equivelant to radio stations.If you want 101.9FM,but it is set to 101.1FM,it won't come in.When the switches match,you are tuned in and hear 101.9FM.If you need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg The link looks universal for Hunter fans,all wired the same.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41597.pdf
Nov 16, 2010 | Vacuums
Explain how to re-wire 16gal craftsman shopvac,switch wires are- 2 orange wires, one white, one black and one green(grd wire), I pulled them off and don't where each wire goes.
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
I hope this helps you
If I have misunderstood your question, please ask again.
a
Oct 05, 2009 | Vacuums
Vacuums Logo
934 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
