Question about Samsung Cell Phones
My samsung guru phone speaker not working,help i can hear others but they cant hear me,pls help soon
pathtricko
  • 24 Answers
SOURCE: Volume control
the ear piece may be dead or if its a flip phone check the flex cable
Posted on Dec 01, 2008
SOURCE: I can only hear people talking through speaker phone
This is a common issue with the Moto Razor and can only be fixed by replacing a part. This phone used different speakers for speaker phone and talk modes.....If you have an old razor laying around that is the same model, you can use its speaker if you believe or can prove it works......otherwise you can buy one for a few bucks. Here is a randomly selected site that sells these parts.
1. Remove the 4 plugs over the screws on the flip top and the screws themselves. 2. pop the top apart and up at the top you sill see where the speaker just sits in there. 3. Replace it the way you saw it in there 4.put it back together Now you can hear your friends without speaker phone!!!
Good Luck!!!! ANd pls rate this post
Posted on Oct 03, 2009
Testimonial: "Thats it!! I had an old Razr and used the speaker out of it and now my phone works again. Thanks so much"
  • 63 Answers
SOURCE: Sony Ericson C905 Speaker problem
This Problem Is Caused By Either Haveing Put In A Ear Piece Or Blue Tooth Head Set Inwhich Case You Should Be Able To Plug It In And Remove It Again And Your Problem Should'nt Persist
Posted on Nov 01, 2009
SOURCE: when i make a call i cant hear the other person
the internal speaker hs gone on your phone - this has happened to me 3 times now - took it CPW and they fix on that day or replace it it seems to be a recurring problem with the C905
Posted on Nov 09, 2009
Testimonial: "thank you very much"
  • 195 Answers
SOURCE: my samsung mobile phone s locked and i'm not
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
Posted on May 16, 2010
Hi, i own a Nokia 5310 Xpress Music...Recently i dropped my mobile down and from that I have problem with my mobile i.e : whenever i get a call,the caller is able to hear my voice but i cant hear the...
First check the speaker or replace it. if this doesnot work then check or change ringer ic.....this has to be done by an expert using hot air gun 4bf42d39-d9c1-4c7d-b217-96cbf6bbe095.jpg
Jul 21, 2011 | Nokia 5310 Cellular Phone
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
Jul 06, 2010 | Nokia 5130 Cellular Phone
I have a samsung u600 i cant hear people onthe
i think you should connect your phone to pc and update it this might help.and if it dosent you have to get the phone checked on shop
Jan 26, 2010 | Samsung SGH-G600 Cellular Phone
Sep 25, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
When I make or receive a call I can't hear anything. The other person can hear me
hi
start your investigation with the volume buttons if the volume is low or some
if this still doesn't work check if you can hear the other party's voice using the phone either with a headset or on the loudspeaker
two possibilities here
1. if you still cant hear on the headset or loudspeaker even after the volume is put to max then there is an audio IC problem on the phone
if you can her the other party on the headset/ loud speaker then you have just identified that the phone speaker is damaged
hope this helped
cheers
pls rate the solution if it was any help
Jun 29, 2009 | Samsung SGH-U600 Cellular Phone
Cant hear anyone
Hi Rommel!
My brother had experienced the same thing, too so I suggest you bring your phone to your local technician. I think it's the phone's speaker that has a problem. Hope this helps...
Ai-ai
May 09, 2009 | Samsung Eternity Cell Phone
Cant hear person on other end of phone
check the ear speaker and replace it with new one..
Dec 08, 2008 | Samsung SGH-G800 Cellular Phone
MIC
Does she have a microphone plugged in? I dont think the 6400 has a built in mic.
If you're sure your mic works then open the sound mixer (click the speaker icon by the time in the lower right) and click "options" then "properties" and select recording. Click ok. Make sure "microphone" is selected.
Hope this helps!
Dec 25, 2007 | Dell Inspiron 6400 Notebook
Cell Phones Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
