Question about PfaFF Creative 7570
I am sewing on thick fabric and the machine gives me a message to put the presser foot in the sewing position. It is in the sewing position, so how do i get the message across to the machine that the fabric is just thick?
    Scholar:
  • 89 Answers
Could be 2 things
A presser foot spring that is gummed up or a bad/durty/out if adjustment/ sensor.
Posted on Apr 04, 2011
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
How do I change tension when I'm sewing a thro for a bed and the material is thick?
You probably need to change the "presser foot pressure" if your machine has the function. It increases or decreases the amount of pressure the presser foot applies to the fabric. You can also try using a walking foot, teflon foot, or roller foot to see if it helps feed the fabric and make a more even stitch.
Mar 23, 2017 | Sewing Machines
HV sapphire 930 not feeding properly
When stitching together a quilt sandwich, it is recommended to use a walking foot on your machine. The walking foot moves the upper fabric in conjunction with the feed dogs. Sometimes, if the quilt sandwich is not too thick, a roller foot can also help but may not be sufficient for a quilt sandwich.
What is Walking Foot Sewing Tips for Beginners
How To Use Walking Foot
How to Use Roller Foot
You may also check the presser foot pressure on your machine. This regulates the amount of pressure the presser foot applies to the fabric and the feed dogs. If the pressure is too strong, it will tend to push the upper layers of fabric, creating a bubble look. If the pressure is too loose, there is not enough pressure for the feed dogs to physically pull entire quilt sandwich under the presser foot.
(The pressure is adjustable depending on the types of fabric and thicknesses being sewn.)
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
http://makeitsew.biz/presser-foot-pressure
Oct 01, 2016 | Sewing Machines
Is there any way to get a brother auto button hole to work on a thick winter jacket
Thick fabric presents some special problems for buttonholes. It may help to place tissue paper (like giftwrap tissue) under and above the fabric to help the fabric slide better. If not using a special buttonhole foot, a teflon foot or roller foot may also help.
Also, consult your owner's manual. If your machine has a presser foot pressure adjustment, it may help to loosen that so the presser foot does not press so hard on the fabric.
Mar 03, 2016 | Brother Sewing Machines
How to change sewing for different thicknesses
First, you will need to select a brand new needle of the type suitable for your fabric. Select a proper thread weight and type for your needle and fabric.
Select the proper presser foot for your project/fabric. On some fabrics, you may even want to use a straight stitch needle plate to prevent the fabric from going down the needle hole.
You will want to adjust the upper tension so that the upper and bobbin threads meet in the middle of the fabric.
Also, probably want to adjust the presser foot pressure so that the presser foot presses harder or lighter (depending on the fabric) so the fabric will feed through evenly, ie both the top and bottom fabrics move together at the same rate. Hint: if it is really thick, like sewing a quilt with batting, a walking foot may be helpful.
Be sure to test on scrap fabric from your project before beginning sewing your project together.
All About Needles
Why is there an extra needle plate supplied with my machine Brother straight stitch plate and presser foot cannot be used with zig-zag or decorative stitch or you will surely break your needle and possible knock the machine out of time!
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwib0Z_YrrbJAhUBUGMKHc6OBhAQFggeMAA&url=http%3A%2F%2Fwww.ca.uky.edu%2FHES%2Ffcs%2FFACTSHTS%2FCT-MMB-213.pdf&usg=AFQjCNE4QlGk1Fvt8K2UGCRCfzMpGS-A2Q&cad=rja adjusting tension
Adjusting Sewing Machine Tension to Prevent Problems
Adjusting the presser foot pressure on your sewing machine
Nov 29, 2015 | Sewing Machines
Thread nesting on the bottom
Rethread the top of the machine with the presser foot up; sew with the presser foot down. If the fabric is too thick/too many plies, the presser foot is forced upwards, allowing the top tension to open. This causes thread snarls on the underside. See also: http://www.picturetrail.com/sfx/album/view/22521551
Jan 12, 2014 | Brother PE770 Computerized Sewing Machine
Trying to sew tab tops on a thick curtain which is lined have got a larger needle and decreased tension but its not working help Using a Brother x3600 sewing machine
Put the tension back to the normal setting - around 4.
Lengthen the stitch to accommodate the multi layers.
When you are sewing and come to a thicker section, stop with the needle down, lift the presser foot and place a folded scrap of fabric under the back of the foot to keep it even. Lower the presser foot and continue sewing.
Mar 17, 2010 | Sewing Machines
Sewing Machines Logo
82 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
