Leaking, possibly internal - Heating & Cooling
You really need to post more information.
Sometimes, when the unit is not level or tilted toward the inside, you can have condensate drip off of the condensers. You could also have a problem with the tubing that empties condensation to the outside - tubing pulled apart, dirt obstruction, rusting, etc.
Need to take off the front of the unit first to see if you can identify where the fluid is coming from. It might be the coolant is leaking.
Posted on Apr 04, 2011
Is leaking water
Leaking inlet or pump out hoses, leaking internal hoses, leaking water pump, crack in drum surround. The possibilities are endless :>)
Sep 12, 2015 | Washing Machines
Codes351/420/442/455 what do they mean
(M) Check Engine Light ("Malfunction Indicator Light" or "Check Engine") will illuminate during engine operation if this Diagnostic Trouble Code was recorded (depending if required by CARB and/or EPA). MIL is displayed as an engine icon on the instrument cluster.
P0351 (M)
Ignition Coil A Primary/Secondary Circuit
Peak primary circuit current not achieved with maximum dwell time.
P0420 (M)
Catalyst System Efficiency Below Threshold (Bank 1)
Catalyst 1/1 efficiency below required level.
P0442 (M)
Evaporative Emission Control System Leak Detected (medium leak)
A 0.040 leak has been detected in the evaporative system. (A faulty gas cap may cause this code). Also see TSB 25-001-02A. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
P0455 (M)
Evaporative Emission Control System Leak Detected (large leak)
A large leak has been detected in the evaporative system. See TSB 25-001-02. Also, possible faulty or loose gas cap. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
May 01, 2014 | Jeep Grand Cherokee Cars & Trucks
Pressure washer itseld turns on
I'm guessing that you have a small electric washer. These come on when triggered.....or if there is a water leak on the high pressure outlet side, at a connector or the gun itself...or possibly some internal leak. It's not likely being worth the cost of a repair if it is something beyond a simple leak. Commonly, the washer will only come on in short pulses. Coming on and staying on would be an internal switch problem unless your high pressure leak is substantial. Leaks are usually just worn, split or missing o-rings at the connectors.
Oct 20, 2012 | Garden
What do the service codes P1281 and P0455 mean?
P1281
Engine is Cold Too Long
Engine coolant temperature remains below normal operating temperatures during vehicle travel (Thermostat).
P0455 (M)
P0455 usually a loose/faulty gas cap or cracked or broken hose to the EVAP canister or purge valve.
P1281 The engine coolant temp is too low probably a bad thermostat.
Hope that helps
Oct 12, 2010 | 2003 Jeep Grand Cherokee
Engine has lots of white somoke on start up and for a couple of minutes then gets better
White smoke is an indication of a possible internal coolant leak. If you have noticed coolant loss with no apparent leak, then suspect a blown head gasket or cracked head especially if this engine has ever overheated. Have a cooling system pressure test run to see if you have an internal leak. Any internal leak will cause serious engine damage and should not be ignored. I would guess you have an internal leak so stop driving this vehicle until you can have it repaired.
Mar 09, 2010 | 2000 Mazda Protege
Why would there be internal leaking into the tray
Never use vinegar to clean your machine. It is possible that the orings are worn out on the brew unit.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
Vac code came on 0455
Jun 30, 2009 | 2001 Dodge Stratus
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
