Question about Haier Dryers
After i plug dryer in and turn the start button it just click only.
  • Haier Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 03, 2011
I push start button and then I click saw. Why do lights flash a couple of times?
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
Plugged up dryer saw sparks...noticed the burn area near the grounding ... I could hear a click til around the 8th turn then tried it and it worked. ... My dryer doesn't initially turn on when I push thestart button, only when I put ...
How To Fix Dryer That Won't Start ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Will-Not-Start/
When the dryer won't start then troubleshoot common parts and problems like ... On alldryers, the door switch allows the dryer to start tumbling only when the door ... Gas and electric dryers have a motor that turns the blower and the dryer drum. ... and Stratton Parts · Echo Parts · Frigidaire Parts · GE Parts · Husqvarna Parts ...Missing: saw
Dec 25, 2015 | Frigidaire Dryers
Sears Dryer 60932 won't start. It won't heat and the motor won't turn on. It is getting electricity because I can hear it click when I hit the start button and hear some faint clicking sounds for a few...
This is a symptom of a blown thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and power to the motor is cut when it blows then the motor cannot run and no dryer function works. Click on the link below for the instructions on how to troubleshoot this kind of dryer problem.
Troubleshooting Whirlpool and Kenmore Dryers Not Starting
Mar 20, 2011 | Kenmore Dryers
Won't start just clicks when i push the start button. When I push the start button I do hear a faint click in the selection ( color, white.etc.) button
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Mar 05, 2011 | Kenmore Dryers
My dryer is getting electrical power. But when I turn the power knob onto ON, nothing happens.
it may be the door switch, but if you hear a click when you push the start button then the motor reset button tripped. You should be able to set the dryer on its front side and see the motor reset buttons as there are two one trips one resets, push the reset in it should click and then plug it in and see if that helped. Hope this helps if not feel free to ask more info as I am more then willing to help Tim
Oct 16, 2010 | Hotpoint NWSR483EBWW Electric Dryer
The dryer wont start when i press the start button
maybe the dry door switch or the reset button on the motor. if you here like a click noise when you push the start button then its the reset. if not then more then likely it is the switch, which means either way the front panel has to come off, screws are located inside dryer door, the top corners are clipped from the inside so a flat tip screw driver will pop the corners, then disconnect switch, if it is the switch remove switch and tape wire together, put front panel on with top clips, plug in and push start drum should turn. get new switch.the reset buttons are on the motor and when you push the reset it will click. Hope this helped Tim
Sep 23, 2010 | Kenmore 63942 Dryer
Dryer won't start
Sep 23, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
