Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
I get "no0p" and have re-set and reprogrammed.
NoOp is fatal failure of timer. According to what others say, battery replacement will not fix problem.
I've read people taking apart timer and adding oil to the gear ?/?, but have not done this myself and cannot say it works for sure.
Intermatic timers come with industry-standard 1 year limited warranty.
Suggest replacing with timer that operates on electric current rather than battery.
Advantage of Intermatic ST01C and EJ500 is 7-day programming -or- astro dawn-dusk function -plus- easy wiring -and- single-pole or 3-way switching. Whereas timers that work on electric current need neutral wire or ground wire to operate timer clock.
For 7-day function only, GE 15071 from Home Depot. Single pole only. Not for 3-way.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
For 7-day or astro dawn-dusk, Utilitec 0192773 from Lowes. Single pole only. Not for 3-way.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
For 7-day-astro-only plus 3-way switching, Aube T1034
http://waterheatertimer.org/Aube-timers.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 03, 2011
Just bought my house and the porch light is controlled by Intermatic timer. Just noticed today that my porch is light is on constant. Replaced the battery in the timer. I was able to set the time and...
Don't forget to reset timer after replacing battery:
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If timer does not function after reset, then buy new timer
EJ500 is rated incandescent bulbs only
Gene
h
Oct 05, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
Tip
How Do I program my iPod Touch
<p>Completely reprogram your iPod touch by performing a "Restore". Do not let the name fool you, Apple's restore feature restores the original factory settings, so the iPod unit is clean, except for the operating system. Access to restore utility in iTunes. If your iPod is frozen or stopped working, first manually reset, and then restore in iTunes. <br /> <p><br /> <p>1. Hold the "Sleep / Wake" button and the "Home" button at the same time as your iPod is frozen or unresponsive. Holding the button until the display converts the iPod Touch in recovery mode. <br /> <p><br /> <p>2. Press the "Home" with one hand while you connect your iPod to your computer with disabilities with the other. ITunes will ask you to restore your iPod in recovery mode. <br /> <p><br /> <p>3. Click "OK" to start the recovery process. When iTunes is finished, your iPod Touch is completely reset, ***** except for the original operating system, and ready to reload with new data. <br /> <p><br /> <p>4. Connect the iPod Touch directly to your computer as usual, a restore point to start, without going into recovery mode. Open iTunes if it does not open automatically. <br /> <p><br /> <p>5. Click the name of your iPod under Devices in the left pane of the iTunes window. "Summary" tab open. <br /> <p><br /> <p>6. Look for the "Restore" button to the center of the window. Click this button. <br /> <p><br /> <p>7. Confirm that you want the iPod Touch to its original factory settings. This is your last chance to change his mind. <br /> <p><br /> <p>8. Wait until iTunes has finished. The iPod is restored to its original factory settings. <br />
on Aug 05, 2011 | Computers & Internet
The Date and Time change back to installation date and programs no longer work
if you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Dec 10, 2012 | Jandy Aqualink RS8 Pool/Spa Combo Control...
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
Timer display says "Lo Battery". I put two new
Intermatic timers might require reset-and-reprogram after battery replacement.
To reset, hold down on-off button and push reset button once.
Keep holding on-off button until display changes.
Release on-off button, and display should blink 12:00
Try cleaning battery carriage contacts with alcohol and make sure battery polarity is correct.
If functionality is not restored, then replace timer.
Intermatic EJ500 comes with 1 year limited warranty and is rated for incandescent light bulbs only.
Aug 08, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Hi, thnks for your help. During the night the air cond stop and the inside unit have the function "PF"
PF stands for Power Failure- either your electric power failed completely during the night, or just dropped too low for the unit.
You will probably need to reprogram the setting on your thermostat, and set the clock (if it has scheduling capability).
If you need a manual/instructions, see if you can find a model name/number on the display unit.
Jul 16, 2011 | Heating & Cooling
I have a Mitel Superset 4025. The "message" button was somehow reprogrammed so that pushing it now calls the operator, I can access my VM using "8" but the message waiting light is...
it's because the operator set a message to your phone. You need to leave the handset on the cradle and push the message button. Read the display and follow the prompts. You should be able to clear the message.
Apr 27, 2011 | Mitel Superset 4025 Corded Phone...
I have an Intermatic timer in my garage that controls outdour switch for holiday lighting. The timer is functioning except I cant get it to go to the off position. It is giving me a error code of...
If the display will not show after replacing battery, try resetting and then reprogramming timer.
If the display will not show after reset, then timer has gone bad.
Link to Intermatic timers
Link to your manual
Troubleshooting steps do not show specific problem you mention
The advantage of Intermatic battery-powered timers is simply hooking up two wires. Plus the DST feature.
Aube T1034 hooks up to 2 wires without needing batteries.
Oct 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Dead set cannot open the unit
hi there i think the problem of your phone is the LCD, you may say its dead cuz' when LCD is damage keypad lights won't work too.
but when you press power on only lights work but no display the problem for that is the software program, and must be reprogram to your nearest service center. ;-)
peace!
Nov 28, 2007 | Nokia 1100
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
773 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
