Question about IOGear 2.5" Hi-Speed USB 2.0 ION Drive II GHD225U40 40 GB Hard Drive
When I try to save my data it always skips some of the files
  • Brian Sullivan
    Brian Sullivan Apr 03, 2011
    how do try to save the files by drag and drop,edit select all copy and paste save
  • IOGear Master
  • 27,725 Answers
Open the page that contains the files select edit then select all copy then back to the destination folder and paste
hope this helps
Posted on Apr 03, 2011
How i can recover deleted files?
Try to insert the digital recorder to your computer and run a data recovery program on it. If you're a Macintosh user, please also give this data recovery app a go. Recover Data from Mac Hard Drive and Storage Device
Jan 03, 2016 | Sony ICD-SX46 Handheld Digital Transcriber...
I have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some...
Don't be panic. you can try some format recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
I have bought a 640GB Transcend Hard Drive.But when I was transferring Bulk Data , I got a error mesage saying that due to some I/O error the data cannot be copied so you have the option to skip...
You can retrieve your data with data recovery program.I have succeed to recover data from crashed hard drive with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash.Download a trial version and scan your hard drive for free to check out whether your files can be recovered.Luck! http://www.any-data-recovery.com/index.htm
Mar 15, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
When I try to use my brother MFC-465CN as a scanner, it does not allow me to scan into a file. It always scans in a PDF file, even it I select scan to file.
You can configure the "File Type" properties while saving as you will see the explanation in this link.
File Type:
This is where you can change the format that the file will be saved in. If you choose PDF(*.pdf) to scan and save the data in pdf format it will be saved as pdf file.
Hope this helps.
Sep 28, 2010 | Brother MFC-465CN InkJet Printer
Wants me to re-format. how can i keep my documents
download recover my file or ontrack recovery. Recover your files from the hard disk and then format your hard drive if you need crack or serial for the software mail me at dpmmishramishra@gmail.com with the subject recovery crack
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I wanted to check the amount of storage left on my zoom h4n sd card. I went into the sd card file via the zoom h4n menu and it asked me if I wanted to format the sd card. I tried to select 'no' but the...
You may try some recovery software to rescue the files on your handy recorder, here are some for your option.
Photo Video Music Recovery (for Windows)
Photo Video Music Recovery for Mac
Both programs can also recover video and music files.
Note: Before your files are recovered, do not attempt to save more files to the recorder in case the original files(your recordings) are overwritten.
Apr 19, 2010 | Zoom H4 Handy Recorder
Accidently deleted files on sd card with hd writer ae . How can i recover the files?
I had success with steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download sd card recovery software, recommended Asoftech Data Recovery (simply because i was using it and it worked) with link below
SD card recovery software
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your files.
Feb 17, 2010 | Panasonic HDC-SD20 High Definition...
How to recover from format error message in walkman
Format error are often shown if the file stored on your Sony NW-E505 is not recognized by the system. Try to review the supported audio formats of your player,use audio (format) converter for better compatibility.
Aug 27, 2009 | Sony NW-E505 MP3 Player
Need to recover deleted videos from HDD
When you delete files the data itself isn't deleted, just the index entry that tells the system where the data for those files is located. The area containing the deleted data is also now marked as free space so it is available for any new files to be written there instead.
So most of the time, you are able to get back deleted files from computer. You may try a free data recovery software to view deleted files so that you know whether the deleted files are recoverable.
One I used to use is asoftech data recovery program which you can download from site below
Aug 09, 2009 | Sony Handycam DCR-SR40 Camcorder
My ps3 isn't loading games
ok, first, copy your save files onto a flash drive or external hard drive. you can either copy an paste your files, or, if you have an external, you can go to backup utility in the settings. If you dont care about your non-online saves and install datas(you can always re-install), you can just skip that part and just go to settings, system settings, and go to format utility. follow the on screen steps and format your internal hard drive. when done, if you copied your files, you can go to system settings and transfer the files back. If this doesnt work then you will have to get a new ps3, but my friend had the same problem, and reformatting his ps3 fixed it.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
IOGear 2.5" Hi-Speed USB 2.0 ION Drive II GHD225U40 40 GB Hard Drive Logo
37 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
