When I restart my computer, the monitor doesn't turn on
  • 1,952 Answers
Check the connection between monitor and cpu
Posted on Aug 05, 2008
Both leds are on
Have you checked the cable and reseated it, check for bent pins in the connectors. Perhaps the Graphics card/adapter is gone.
Mar 05, 2013 | HP Compaq d530 CMT PC Desktop
Problem stating up pc
check to see if your vga cable is properly connected at both ends i.e. at the monitors end as well as the computers end. In case it doesn't solve the issue then your vga port is damaged.
Aug 15, 2012 | HP Pavilion a1310n PC Desktop
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
I have a HP Pavillion a6228x PC and the monitor turned black, but the computer is still running. We have restarted it but it turns black again after turning on. What is the problem?
Have you check the monitor? maybe the problem is in the LCD monitor or the CRT. If the monitor is good. Then check your computer's hardware. Is there a Video card on your computer?. If there is one the remove it, be sure that the computer is turned off before removing the card. Then use the on board video output usually color blue. Then turned on the computer again.
Hope this may help you
Aug 23, 2011 | HP Pavilion a6228x PC Desktop
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
My acer monitor p191w will turn on acer logo comes on goes black then a screen comes out saying no signal then turns of light turns yellow ...tried restarting monitor nothing
Connect the monitor to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer really is "sending" a video-signal through the "data" cable. If not, then either the data-cable or the video-card inside the computer is faulty.
Jul 13, 2011 | Acer P191WBD LCD Monitor
In the middle of reading e-mail the monitor went black, no flicker, no warning, no warning
First I would check to make sure it was still plugged in, you never know, things come loose sometimes.
After that check and make sure that the cable that runs from the back of the monitor to the back of your computer is still plugged in. If it's loose push it back in.
If that's still not working, try turning the monitor off and restarting your computer, and then turning it all back on.
If all that doesn't fix it, then it's probably just gone bad. So either get a new one or if it's still under warranty send it in for repair/replacement.
May 25, 2011 | HP Compaq 1701 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
