Question about Anishu iPhone Apps
Ipad version crashes and will not open. This happens periodically. I have deleted and reinstalled app several times. This happened last year and developers could not figure out the problem. I started from scratch (lost a years worth of data). Now it's happening again. It works perfectly for a couple of months, and then it stops working (won't open). Restore does not work. Sending initial data from the iphone does not work. Yet, the ipad icon shows the correct number of bills due to be paid. As a side note, when I delete and reinstall the app it opens and seems fine. The app when opened shows no data; however when closed, It shows the correct of bills due on the icon.
premtech
  • 934 Answers
SOURCE: lost time display
The electrolytic cap responsible for hold the information locked in the eprom has most likely failed or is reading so high an equivelent series resistance as to be useless. That, and probably several others need to be changed out. Radial caps in a circuit, commonly referred to as lytics, act like a battery storing up electricity and dispensing it at a proper rate in their given circuit. After time the oil like fluid in them begins to deteriorate and the lytic breaks down becoming less able to function. Some simply open and this circuit collapses. But others, like the problem you have here, slowly die off and are not able to dispense voltage at a rate necessary to keep the charge across the gate of the IC storing the info you just programmed into it.. So, in laymen's terms it needs to go to the shop and have a few caps tested... Not an expensive proposition so I'd clearly recommend having it repaired. To do this yourself you would need at a minumum an ESR meter, which is more expensive than the repair will cost you... Hope this helps. Bill
Posted on Jun 07, 2007
Door Tech
  • 98 Answers
SOURCE: Craftman garage door opener, will not go all the way up.
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of               lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken           or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling          and reads Craftsman). If the light(s) on your operator go from front and/or back, the force                      adjustment screw is on the back of the operator. If the lights are on the sides of the operator then          the force adjustment screw is on the right side (looking from the back of the operator and facing            the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Posted on Jan 01, 2009
  • 10406 Answers
SOURCE: Webroot spysweeper with antivirus won't open anymore
My advice: uninstall it, and install the _free_ anti-virus software from Microsoft: http://www.microsoft.com/security_essentials
which does _NOT_ require any "key".
Posted on Mar 07, 2010
pappapumpdaf
  • 635 Answers
SOURCE: Rosetta Stone Starts but the home screen in blank
Sounds like you saved your progress file in a non Rosetta Stone folder and now it can't associate the progress with any language packs.
Posted on Mar 09, 2010
  • 1382 Answers
SOURCE: My camera stopped working suddenly. When I turn
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jun 01, 2010
Testimonial: "Thanks for the feedback! I tried this and another solution I had found, and it now works!"
High5casino will not open
This could be because of many reasons. Your iPad may not have enough space for the app to download. The download might have been accidentally stopped if you went offline for a period of time. The easiest way to fix this is to delete the app and then reinstall it.
May 30, 2015 | Apple iPad Tablets & eReaders
When I received this iPad from my daughter & loaded my Facebook it opens in her Facebook. She had every thing removed & reset before she gave it to me.
Get your daughter to go into her Facebook account.
Ask her to go into account settings. You will find an area that allows you to sign in it of ALL devices.
This should disconnect her Facebook account from your iPad.
Uninstall the Facebook app. Soft reset the device (power and home button) then reinstall the app when it comes back on.
Let me know if this helps.
Apr 28, 2015 | Apple iPad 32 GB 3G Tablet PC
Why do the apps on my iPad 3 blink when I am trying to delete them? Then the screen keeps blinking.
Not sure what you mean with blinking. When you press an app for several seconds, they all start wiggling. Only the ones with a little x on the top right, can be deleted by tagging the x.
But first reset the iPad by pressing both the home button and the on / off switch till it switches off. Wait more than a minute and switch on again.
Be aware you can delete apps and later reinstall them for free, on the same account but for games all settings and scores will be gone.
Mar 29, 2015 | Apple iPad 3 Tablet 64GB White WI-FI
My Facebook has crashed, what do I do ?
perhaps you are looking at the wrong thing as the problem. it sounds like the Ipad or whatever the tablet is might be the problem
Jan 02, 2015 | Apple iPad (16 GB) WiFi Tablet PC
I can't open the zynga poker now what caused this it has done the sme thing too my candy crush this all happened. After I got my last up date
Try closing all apps then restarting the iPad. To do this, double-tap the home button to bring up multitasking, then swipe each app up to close it. Once all of your apps are closed, turn your iPad off then back on again. This will fix the crashing problem.
Sep 30, 2014 | Apple iPad 32 GB WiFi Tablet PC
App updates do not complete
1. Try one at a time 2. You will come to know which app is stalling the other two 3. Then take back up for the one that is not getting installed or updated. 4. Try updating if does not happen delete and re install
Dec 26, 2013 | Apple iPad Mini
Ipad app keeps crashing every time i open it
Try to update it (if possible)
Dec 07, 2012 | Apple iPad HD
We Farm Safari tries to connect but shuts back down. I've done a hard-set 2-3 times. Is it a bug in the app. ? Apple IPad Since ngmoco added new items to purchase..... 2 days now Doing hard-set on my...
Here are a few troubleshooting things you can try!
- Make sure that you aren't using an old version of the application.. Check the app store and check to see if there's an update available! Many online applications require you to have the latest version to use them.
- It can also be a flaw in the application, so you might want to look up the application on the iTunes Store and read the recent reviews to see if anyone else is having the same problem as you.
- I suggest deleting the application on your iPad, and then reinstalling by syncing your iPad to your computer. If the application is already synced to your computer, deleting it and resyncing after you delete it should allow you to reinstall it and it may work then.
- Also, make sure that the internet is connected on your iPad! I'm assuming this is a web-based game so it may not work when not connected to the internet.
- Finally, sometimes applications like this do not work if it has not been updated for the version of iOS that you have. Check your version on your iPad by opening the settings app on the home screen, then click General > About > And scroll down and you will see the version number. Look up the application on the iTunes store and make sure that you have above the version that is shown.
Good luck! :)
- Julian
Mar 09, 2011 | ngmoco We Farm
iPhone Apps Logo
344 people viewed this question
Top Anishu Apps Experts
Bill Boyd
ray gallant
Are you an Anishu App Expert? Answer questions, earn points and help others
