My samsung split ac is not cooling. there is air blowing no cool air .before the roomwill get cooled within 30 minutes.
  • 40 Answers
Could have leaked out all its gas. if its an older unit it may be cheaper and easier to replace the whole unit. will make a buzz noise occasionaly from the outdoor unit. this is the compressor tring to pump the gas that is not there. check if the fan on the outdoor unit turns on.
Posted on Apr 04, 2011
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
I have two split system Conia rev. cycle air cons models CA30003. Both have "died" within a month of each other. They are just over 3 years old. The cool cycle just switches itself of and blows...
It's likely low on refrigerant and freezing...turn it off, coil thaws , cools for a short time and freezes up again. Chances are the leak or leaks are at the flares where the copper connects to the unit. Need leaks repaired and systems recharged.
May 15, 2017 | Heating & Cooling
I av lost my manual. Pls kindly give me details on each of the samsung split AC 5way. I mean what each symbol means
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Jan 19, 2011 | Heating & Cooling
SPLIT AC NOT COOLING AFTER 30 MINUTES
sounds like the out door fan is not running and the comp is over heating, rec to start unit and check to see if the fan is running in the first 30-45 min, if not check cap or replace fan motor.
Jul 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Samsung split AC is not cooling. Compressor is on and there is air blowing but no cooling. I have also cleaned the air filter.
Most probable short of refrigerant. Would have to have atech put guages on it and check.
Mar 09, 2010 | Heating & Cooling
2001 nissan altima limited edition
it is not engine thermostat.Your engine temp is normal right? doesnt sound like expansion valve. which is basically thermostat for a/c system. make sure your cooling fans are coming on and no trash on condensor this is in front of radiator.
Sep 08, 2008 | 2003 Nissan Maxima
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
195 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
