Need instructions for concord model 513S-G/series 52CT5 ceiling fan/with lights. was given to me without. thanks lexie
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
mohammed387
  • 1952 Answers
SOURCE: I need an instruction manual to put my fan up. I
www.neonlightceilingfanstyles.co.cc/hampton-bay-ceiling-fan-instruction-manuals/ - 18 hours ago
Posted on Feb 24, 2009
SOURCE: Need instalation instructions
I bought two of these(model 99328). Would be happy to send you instructions from one of them.
Where should I send?
Posted on Mar 12, 2009
moel64
  • 18 Answers
SOURCE: Need instructions to fix ceiling fan - Hampton Bay 55295 + remote
if you tell me what colors of the wires you have on the fan y what colors of the wires on the ceiling may be can help you here is my E-mail: mhernandez781@hotmail.com.
have nice day
Posted on Jul 15, 2009
How do I find light kit to work with my Concord ceiling fan? Concord Series 5200-4/3 Serial # HC1131
Have you searched the Internet? You can find just about anything concerning just about anything on it. If not, try one of the home improvement stores or maybe you have a store near where you live that carries Concord fans.
If none of this results in success, you may be able to find a "universal kit" to install on your fan.
Nov 22, 2014 | Dryers
I have a Concord ceiling fan, and cannot access the light bulbs to change them? Please help?
Try spraying some WD-40 around the ring of the glass & push up & back & forth until the glass loosens up (hopefully).
Aug 18, 2014 | Dryers
We want to take the light kit off of a 48" Concord ceiling fan. We need a cap or a cover for the bottom. How do we buy one?
I think you have to take the light kit off the bottom cup & put the cup back on the fan. Should just need a filler plug or screw for bottom of switchcup.
Aug 10, 2014 | Dynasty Concord | 52DY5RI | 52" Ceiling...
I just need to know how to install this in an old house to replace a ceiling fixture and install a ceiling fan without having to make a huge hole in my ceiling. I can't find any instructions on the model...
If you're trying to replace a light fixture with a ceiling fan. The most important thing is to make sure that the electrical box in the ceiling can support the weight and momentum of a ceiling fan. If it's an old house, as you say, I suspect it's not. However, there are support kit, that you can but from most home centers, that will install without having to make a "huge hole" in your ceiling. If you have an attic above this room, accessing and beefing up the support of the electrical box would not be difficult. If you don't have that luxury, then the support kit is your best solution, as you don't need to have access to an attic above.
As far as the Model # 22200 is concerned ... Since you didn't mention what it was, I don't have a clue.
In any event, I hope this helps you in installing the ceiling fan. Please let me know and if you would please rate my response to you. Thank you!
Mar 25, 2011 | Heating & Cooling
I have a Concord Series 52PA5, Model HC-1993OS. The fan speed switch has been cut out. I want to wall switch it and only fun fast speed. What color wires do I hook to the 110?
Generally speaking, your blue or black wires are going to be hot. Your white wire is going to be neutral and your green wire is going to be ground.
Aug 21, 2010 | Concord Fans (52MA5WH) 52'' MADISON...
Light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Mar 27, 2009 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
780 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
