Question about BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal
My boss DD-3 makes a strange tapping sound on all modes. tapping sound gets more frequent when i turn the delay time pot to the right. its like a little tap sound getting into the circuit with the guitar signal and gets repeated all over.
  • BOSS AUDIO S... Master
  • 5,603 Answers
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
Posted on Apr 03, 2011
Battery problem
DId you remove the plug from the input jack to turn the pedal off? If so then you may have a bad input jack.
Jul 03, 2013 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
Aug 17, 2012 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My Boss Digital delay pedal won't stay on unless I keep my foot on it.
This is likely a failing switch under the pedal. Either the toggling mechanism is broken in it or if it is a momentary type it probably has "contact bounce" that exceeds the what the de-bounce circuitry can handle.
Mar 08, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
After many years of successful use my DD-3 dig.delay foot pedal has broken. There is a black plasic switching device sited near the main spring which has come free from the main metal seating. Also a...
Find a local handyman, preferably one with electronics skills as well. Sounds like you need one that knows adhesives... DO NOT use super glue for any of this repair... it is too brittle and will soon break again.
Use epoxy for broken parts... JB Weld is pretty good.
Aug 16, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
I turn on the Pedal and all sound is gone turn it off and the sound is still gone
Contact Roland (UK) Ltd on 01792 702701. Speak to a service engineer who will tell what is required. If it is a replacement part, they will send it.
Jul 01, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Ive got a delay ,chorus , wah ,distotion and compressor . how would i aet them in which order . thanks
Generally speaking, other than having hte compressor first to provide a consistant level to the other pedals, the order is personal preference. You need to experiment and determine the types of sounds you want. There is no "standard" order.
Dan
Feb 03, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My boss digital delay works when engaged but no sound when not
sounds like the true bypass line has been damagd. Should be easy enough to fix. Pop open the unit and do a visual inspection first, if nothing is noticeable then do a continuity check with an ohm meter from input to output with the delay efffect off. If you don't read a short in this situation then your problem lays within the signal path and its switched path.
Jan 17, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My Boss DD3 just beeps and nothing else when i turn it on
If you have experience with electronics you could take it apart and use a multimeter. My guess would be one of the delay chips but its something hard to diagnose without taking it apart. An audio tech could help you out. Chances are it would be a pretty cheap fix. Unfortunately Boss pedals are almost entirely surface mount so replacing a component or two takes more skill than the average pedal.
May 16, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
My boss dd-3 pedal only works with a 9v battery. When I hook it up to the 9v apaptor, (a boss) it freaks out and does nothing. Can you help? Everything seems solid. the jack doesn't wiggle or anything.
You will have to test the adapter with a volt ohm meter to make sure it is putting out the proper voltage. It should be as close to 9 volts as possible. Also make sure that thehole in the plug is negative and the outside is positive. Is it the right adapter? I don't have a schematic for this model but www.schematicheaven.com has one for a DD-2. Hopefully they haven't changed too much. If you decide to repair it yourself, check the adapter first then check for a bad solder joint where the adapter plug is soldered to the circuit board. Hope this helps somewhat.
May 14, 2009 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal Logo
203 people viewed this question
Top BOSS AUDIO SYSTEMS Music Experts
Michial Gueffroy
Are you a BOSS AUDIO SYSTEMS Music Expert? Answer questions, earn points and help others
