Question about Gardner Bender Gsw-34 3 Speed Pull Chain Switch Gsw-34
I have a Gardner Bender 3 speed pull chain switch I am trying to replace on a ceiling fan. The switch did not come with attached wires so I stripped the existing wires and marked where they go. How do I insert the stripped wires into the switch? When I try and push the stripped twisted wires into the slots, they just bend and don't go all the way in.
  • Handie Andie
    Handie Andie Apr 03, 2011
    Are there screw connections also? It is always best to use the screw connections. Most electricians will tell you that the stab type connectors come loose often. Do not use them myself.
    Stranded wire is not used for stab connections.
    If that is the only connection possible, please write back.
    Hope this helps. If it does, please place a vote for me. Thanks,
    Handie Andie
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: purchased a Gardner Bender 3
Here is how I would hook that up...
L-white
1- black
2- blue
3- red
heatman101
Posted on Jun 06, 2011
Wiring diagram to rewire
I think this is what you are looking for.
Jul 01, 2013 | Gardner Bender Gsw-34 3 Speed Pull Chain...
We have green, black, brown and gray wires coming from the fan. Where are they connected into the GSW-34 switch?
Replacing 4-wire 3-way pull-chain switch is usually not that simple, since old and new switches might not be compatible and should be tested first using multimeter or continuity tester.
Open following link for step-by-step testing to see if old and new switches are compatible:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical wiring or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Gardner Bender Gsw-34 3 Speed Pull Chain...
How to replace a 3 speed pull chain
Open following link for illustration and instructions:
As a general rule, the new 3-speed switch has to have same number of wires (either 3 or 4).
The new switch and old switch have to match electrically, which means the old and new switches have to be tested with a continuity tester or multimeter (both testers available at local hardware).
Testing is necessary because wire colors do not always match and because each pull chain can activate different wire or combination of wires.
Add a comment for more assistance as you work on the project.
Take a moment and vote on answer:
For a price, expert works with you while you work on 3-speed switch or any do-it-yourself project.
Aug 28, 2011 | Gardner Bender Gsw-34 3 Speed Pull Chain...
I am replacing the gsw-34 3 sp. pull chain switch . i have the wires marked. do i have to cut the wires off the old switch or do they release somehow? they are the stab connectors.
There are 2 type switches. First type will have spring loaded connectors that hold wire into each hole. To remove these, press on slot on bottom of switch with a little screwdriver & pull wire out. Repeat for each wire. Each wire on switch has a number. Just push wire in replacement switch with corresponding number & it will click in & stay in. The other type switch will have little wire nuts attached to each individual wire within 6 inches of switch. Untwist each wire & reattach to new switch.
Apr 04, 2011 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Can you please let me know how to wire in a GSW-31 pull chain switch interupter. Thankyou
Hi and welcome to FixYa, I am Kelly.
You wire it up in series... Usually you cut the black wire and install the switch wires between the cut wires. All the switch does is open 1/2 of the circuit. (one leg) If your power wire is not black then find the power wire attach one side of the wire to incoming power and attach the other side of the switch to the load / light / fan / what ever.
Thanks for choosing FixYa,
Kelly
(Electrician since 1960's)
Mar 26, 2011 | Gardner Bender Gsw-31 Pull Chain Switch...
I am replacing the 3 speed fan switch in a ceiling fan. Upon removal of the old switch (due to a cracked/broken screw port), I noted the secific wire and color that was located in each of the four...
Use a continuity tester on old switch.
There will be 1 main wire that connected to power >>> power flows through this wire to the switch and feeds the other 3 wires > each time you click switch, power will flow to one of the other three wires
The do the same test on new switch. Match up wires accordingly.
If you don't have a multimeter, buy inexpensive continuity tester at hardware store.
Continuity tester is basically a flashlight battery and flashlight bulb that lights up when the circuit is closed
Oct 16, 2010 | Gardner Bender Gsw-34 3 Speed Pull Chain...
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Feb 08, 2009 | Monte Carlo (5LCR52MW) Fan
Gardner Bender Gsw-34 3 Speed Pull Chain Switch Gsw-34 Logo
224 people viewed this question
Top Gardner Bender Electrical Supplies Experts
Gene Haynes
Steve
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
