Question about Creative Labs Creative Internet DECT Phone
My computer turns blue
Saying that is saving my computer from a data loss, that i have a hardware or software incorrectly installed, but i unistall all my stuff and istalled again, but still the same problem, the computer just turns blue and i have to restart it,, can u help me please
    Problem Solver:
  • 6 Answers
Uninstall the driver for your phone first. Find a registry cleaner online and run it before installing the phone driver again. p.s do not plug the phone in before you install the software.
Posted on Mar 08, 2009
Problem connecting PSR I425 to computer.
how to psr i425 recording data tranfar to computer ...plz reply
May 27, 2010 | 2003 Yamaha YZ 125
Can not access my usb scandisk stick. The System see's it but it wants to reformat it.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
Mar 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot unistall driver for Live! cam voice. I
Please go the Disk clean up and clean all necessary things and start a disk defragmentation. Then shutdown and restart the computer and reinstall if it doesn't work i will give you another solution
Jan 19, 2010 | Creative Labs Live! Cam Voice Webcam
PC shuts down when camera is connected
can you reformat the memory?
Jul 27, 2009 | Cameras
My scanner will not "save as" or "scan to". It is an HP 5400c. It gives me an error message and then shuts the program down for me to restart it again. The print function works. I uninstalled another
ok try this and if does not work, call HP and they should send you a replacement. ONLY TRY MY SOLUTION if you have the software to reinstall your scanner.
Go to my computer right click and go to properties, go to hardware, device manager, and find your scanner in the list should be under imaging devices. Click on it once you find it and click unistall. Let it unistall
REBOOT and reinstall with the software. And then try it.
You can also have it install it by going back to device manager right click on your computer name and scan for hardware changes
May 25, 2009 | HP Scanjet 5400c Flatbed Scanner
Pc restarted
Irrespective of being a PC or a Mac the computer system behavior and consistency are dependent upon certain factors. These factors are broadly divided into software factors, hardware factors and the surroundings.
The common software factors leading to a logical failure are:
i.) System files responsible for handling control to the operating system missing or corrupt
ii.) Unsigned drivers or drivers trying to access read only system area
iii.) Operating system files corruption due to incomplete automatic update, malicious software
The common hardware factors leading to a physical failure are:
i.) Problems related to mainboard in terms of the chipset or connector, power supply issue like incompetent power supply to run the hardware setup
ii.) Problems related to hard drive itself or the data or power cables
iii.) Improper setup of hard drive cooler fans (if any)
The common surrounding factors leading to data loss are:
i.) Heat dissipation issues related to closed or poorly ventilated surroundings like in a basement or store
ii.) Moist surroundings leading to the formation of thick dust layers and thus increasing heat
iii.) Direct sunlight leading to extra heat and thus hardware failure
We should logically negate these scenarios so that we can narrow down to the root cause of the problem and take corrective measures.
In case we find that the data loss is due to any logical failure, we can use data recovery software as they are programmed to meet the challenges due to all kind of logical crashes. They scan through the file system, locate all the files which are marked as deleted and are distributed as fragments across the partition, logically rearrange them as per the file system information and then recover them. The data recovery software are indispensable in cases like file system corruption, hard drive formatting operating
system corruption, accidental file deletion or malicious software like virus, spyware etc. We can perform a ‘Do It Yourself’ data recovery using these utilities as they are self descriptive and User friendly.
We need to install the data recovery software on another hard drive which is bootable. We can also use a different working system preferably using the same operating system platform as for MS Windows. Then, we can attach our hard drive to the same for scanning. For attaching the hard drive we nowadays use USB 2.0 Hi Speed or IEEE 1394/Firewire Cables, Attachments or Enclosures. The same can be achieved by a Master and Slave setup that requires hard drive jumper operations and thus is a little complex. We should avoid any other jumper operations as of the mainboard as they may lead to unstable system behavior based on BIOS settings.
We should always save the recovered data on a healthy hard drive.
In case of data loss due to hardware failure where the hard drive is either not getting powered or can not be recognized by the BIOS, we need to go for hard drive recovery service. The data recovery service is personalized help, delivered by data recovery experts. Such experts can extract your data in all possible scenarios of physical data loss.
Apr 03, 2009 | Intel D101GGC Motherboard
I cant get them to come up it said to contack you
there is your hardware problem i think its a blue screen error check it your hardisk is working and ram also check the connection of hardisk if its conected properly then go to the bios setup and check it the sata cable is enable or disable its enable then disable it or turn on your computer keep press f8 button and go to safe mode and check it the new software is install its working perfectly if not then unistall it or restore your computer last known configuration may be its help or re install or repair your windows
Sep 27, 2008 | Computers & Internet
Computer keeps freezing up and often gives me a message that says microsoft not responding
Did you install software recently? Did you add on any hardware? You might need to unistall whatever you installed and/or remove whatever hardware you added.
How much memory you have? How many start up programs you have running in the background. There could be numerous things going on that would give you freezing and non response.
Jul 01, 2008 | HP Computers & Internet
Blue screen
unistall recently installed hardware or software and try otherwise format the system and reinstall operating system it work ok, till the same problem if you have two rams remove one ram and check
Mar 26, 2008 | EPoX EP-8KHA+ Motherboard
Computers & Internet Logo
Top Creative Labs Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
