Question about Navman GPS
My VHF 7000 is not responding with the handpiece and?or changing channels on the unit itself. Can I replace the handpiece cord to unit as the insulation has worn and can now see the colured wires.
    Scholar:
  • 149 Answers
Pull the hand piece apart and drain the water....
Posted on Apr 04, 2011
  • Jim Giesen Apr 04, 2011
    I was actualy working on this unit, from BME time 05 and found it was full of water...
    Trying to find a replacment lead...
THE CORD ON THE HANDSET IS BROKEN TO THE SIDE WHICH IS CONECTED TO THE BASE UNIT. I TRY TO SOLDER IT TO THE PINS BUT WHAT COLOR GOES WHERE?
Phone connections are low electrical connections. Soldering would cause heat dispersion fluctuations, creating more complications. Best to replace cord or unit.
Sep 02, 2015 | Raymarine 240 Vhf Radio E42001
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
How to replace electolux 7000 cord
These canisters are not easy to change the cord in. If you're somewhat handy and know how to disassemble the machine, it is more cost effective to just order a cord winder complete assembly and switch them out yourself! It's most likely less expensive than the labor and parts you'd pay to have it completed! I have them! Hope it helps! Thanks!
Aug 26, 2014 | Electrolux Vacuums
My Channel Master CM-7000 D2A TV Converter box is stuck with Red Light ONLY. Does not respond to any button I press. There is no picture
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum:
C14 - 4.7ufd 50v UPW1H4R7MDD
C4 - 1ufd 50v UPW1H010MDD
C8 - 100ufd 25v UHE1E101MED
C10 - 470ufd 16v UHE1C471MPD
C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad.
C1 - 22ufd 400v EEU-EE2G220
C7 - 220ufd 25v UHE1E221MPD
C11 - Same as C10
C13 - Same as C10
Logic board:
E5 - 33uf 35v EEU-FM1A471
E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Contact me if this is beyond your skills for possible repair.
Nov 06, 2011 | Digi Channel Master/tal to Analog...
In Thailand Cb radio users must use freq range 245.000 - 249.999 freqs. Do usa Cb's use this freq?
Thailand actually has three "CB" bands, the first is the same as the U.S. / CEPT (EU "European Community) band 26.965 - 27.405 MHz, the second is a 78MHz VHF mid CB band (I think its either 40 or 80 channels with FM mode) and then the 245.0000 - 245.9875 MHz VHF 80 channel band - apparently the law also stipulates that the 78MHz CBs must be yellow colored and the 245MHz CBs must be red colored.
But yeah, 245MHz Thailand VHF CBs are very illegal in the United States.
Jun 24, 2010 | Cobra 19 DX III 40-Channels Base CB Radio
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
VHF stations WILL NOT display. UHF stations WILL display. Have tried both the remote and the controls on the TV. What is the solution?
a no ufh channels would be a setting in the menu, but when your vhf channels go, the problem is typically the tuner itself, or the band switching ic. could be either. you will need a schematic to know what voltage is supposed to be on the pins.
Jan 24, 2007 | Zenith B25A10Z 25" TV
GPS Logo
205 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
