Question about Soleus MC-88 Indoor/Outdoor Party Fridge
Iown a soleus mc-88 fridge. I noticed today the sides are hot to the touch. Doesn't seem right, but never really noticed so can't tell if this is normal or not. seems to be working fine but I'm concerned that it may be a fire hazard. Any thoughts?
3 Suggested Answers
bombardie993
  • 44 Answers
SOURCE: SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Posted on Nov 15, 2012
  • 3 Answers
SOURCE: My Soleus dehumidifier has stopped working after one year.
Buy a new unit, put the defective one in the new unit's packing materials and return it for a refund.
Posted on May 21, 2013
Sides of Haier Compact Fridge are very hot to the touch
On some small units such as this, the condenser coil is actually in the walls of the cooler. It is not that unusual for this type of construction. I have seen this in chest freezers and other such units. If the unit makes the desired temperature, I would watch it for a day or 2 before putting any product into it to ensure it is okay and so you don't loose any product.
Sep 06, 2017 | Haier HNSE045 4.5 Cu. Ft. Capacity Compact...
I've got a Samsung Fridge (model RL34SCSW1, http://www.samsung.com/au/consumer/home-appliances/refrigerator/bottom-freezer/RL34SCSW1/XSA/index.idx?pagetype=prd_detail). Recently I switched it off for a...
The 15 sec burst sounds silly to me but you were right to let it settle for a while before starting although 45 deg should not harm the fridge at all. As for the heat on the sides if the unit is working well (cold enough in both sections and shutting on and off) then I would suggest it is fine. If the fridge is working hard the gas entering the condenser is up to 150 deg. F or more it can be very uncomfortable to touch even after travelling a distance to the sides of the unit.
Feb 26, 2011 | Samsung Refrigerators
I have a soleusair party fridge.model MC-88/MC-88S/MC-88SB
It's your fan, take the wheels off, unscrew the bolt that holds the wheel bracket on, take the screws out of the black plastic surround and pull it off the bottom. The unit is connected so don't pull out too far. The fan is plugged into the "motherboard", just use pliers to unplug, take the two screws out of the fan and look for a replacement. No, Soleus does not sell parts. Look at a computer repair store of your choice for something similar.
Jul 11, 2010 | Refrigerators
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fridge humming and hot to touch between fridge/freeze (side-side)
It sounds like your compressor is going bad. The part you mentioned being hot is normal.
Jun 25, 2009 | Refrigerators
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Jan 18, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Top and back of Kenmore dryer feels very hot to touch
this alway in a indication of a venting issue it would seem that it is not in your venting that you can see but it may be plugged up in the wall somewhere in this case you will need a pro. chimney sweep or THE DRYER VENT WIZARD if there is one in your area to come and clean your vents
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | Dryers
Soleus MC-88 Indoor/Outdoor Party Fridge Logo
21 people viewed this question
Top Soleus Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Soleus Refrigerator Expert? Answer questions, earn points and help others
