Question about Microsoft Office 2003 Basic Edition English (s55-00066) for PC
I want to remove micro software form desktop how
  • 374 Answers
If you only want to remove the shortcut from the desktop (not the entire program) Right Click on the desktop icon and left click on remove, If you want to remove the entire program, click on Start, then click on Control Panel and then double click on Ad dRemove Programs. Highlight the program you want to remove and then click on remove.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Posted on Apr 03, 2011
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
Tip
Microsoft Full Form
Microsoft - coined by Bill Gates to represent the
company that was devoted to MICROcomputer SOFTware.
Originally christened Micro-Soft, the '-' was removed
later on.
on Sep 17, 2010 | Computers & Internet
What is the form factor for hp pavilion a1423w
if it's a RC410-M (it should have a number on the motherboard) it will be a micro ATX. • 24.4cm(L) x 23.0cm(W) Micro-ATX Form Factor.
Sep 15, 2012 | HP Pavilion a1423w PC Desktop
Please remove ginuine micro software from my desktop
hell iam vishal i will tell you solution,
to remove the software you need to run your system in safe mode
1)restart your pc
2)press 3-4 times F8 then it will load safe mode and press enter
3)go to control panel--add or remove programs
4)select uninstall
or you can downlaod the microsoft uninstaller simply to install...
best of luck!!!!!!!!!!!
Apr 04, 2011 | Computers & Internet
What is the motherboard form factor of the Sony VAIO PCV-J120 PC Desktop motherboard?
Micro-ATX (mATX, or MATX)
To be sure there is a guide to use.
A full ATX form factor motherboard measures 12 inches by 9.6 inches. 305mm by 244mm
(9.6 inches is approximately 9 and 9/16ths inches)
A Micro-ATX form factor motherboard measures 9.6 inches by 9.6 inches. 244mm by 244mm
http://en.wikipedia.org/wiki/Motherboard_form_factor
(Scroll down)
Regards,
joecoolvette
Dec 12, 2010 | Sony VAIO PCV-J120 PC Desktop
I would like to move it in to a bigger case
When looking at the specifications of the HP Compaq DC7700 SFF Desktop PC, all they state is the motherboard form factor is, 'Custom'.
Same thing for the DC7700 USDT Desktop PC.
Both of these desktop computers are of the 'Pizza Box' design.
(Flat rectangular box)
The DC7700 CMT model is a tower model, and the motherboard form factor for it is uATX.
uATX can also mean Micro-ATX.
The form factor of a Micro-ATX motherboard is 244mm by 244mm, or also said as 9.6 inches by 9.6 inches.
To regress for a moment, and explain the term Form Factor.
This term is supposed to apply only to motherboards, but has gone on to apply to computer cases, and power supply's.
Form factor means the dimensions of the motherboard, and also where the I/O area is located.
[I/O = Input/Output
Area for the Input/Output devices that are attached to the computer.
Examples: Mouse, Keyboard and Monitor]
Whether the motherboard is installed onto the Left side of the computer case, and the I/O area is on the Left side also (ATX , Micro-ATX, and uATX form factor),
or
whether the motherboard is installed on the Right side of the computer case, and the I/O area is on the Right side also. (BTX)
Dimension sizes:
ATX is 305mm x 244mm. (12 inches by 9.6 inches)
Micro-ATX is 244mm x 244mm (9.6 inches by 9.6 inches)
Above the link is the Maximum size for the Micro-ATX form factor.
It can also be the Minimum size of 171.45mm x 171.45mm
(Or 6.75 inches by 6.75 inches.
6.75 inches = 6 and 3/4 inches)
Point of all this?
The motherboard form factor inside a DC7700 SFF is probably a uATX form factor, and is 6.75 inches by 6.75 inches.
Or some variation thereof.
It's a custom size.
This means good luck in finding a computer case you can buy off of the shelf, and is large enough to install an ATX power supply.
You can get a custom one made, and you're probably looking at $150 to $200.
Or, you can modify one of these computer cases VERY easily,
1) http://www.directron.com/cs888uvbl.html
The above is an Acyrlic plastic computer case. It's approximately 1/4 inch thick for the case walls, bottom, and top.
VERY sturdy.
It has metal Standoff's that are set up for an ATX motherboard.
It should have holes in the case where a Micro-ATX motherboard can be mounted, by unscrewing the Standoffs, and screwing them into the Micro-ATX holes.
[A Standoff is a piece of metal that is hex shaped, and has a threaded hole in one end, and a threaded end on the other side ]
If there isn't the proper holes for mounting your motherboard, you make the holes.
The case is plastic.
Uses an ATX power supply.
The cost of the case is $50
Mar 08, 2010 | HP RT810UTABA - HP dc7700 small form...
Is the motherboard an ATX form factor?
The motherboard form factor for a Dell Dimension 5100 is a Micro ATX.
Regards.
Jan 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
No sound
no sound after your remove sound software. try removing hardware sound driver remove sound software. restart system when windows see sound hardware wants to install a driver don't install the sound driver software it install driver and sound package. should fix problem let me if it helped thanks good luck
Mar 21, 2009 | Compaq dc7100 Small Form Factor (PJ361UA)...
Microsoft Office 2003 Basic Edition English (s55-00066) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
