Question about GE Dryers
My GE dryer model dpsb613ed1ww. Clothes won't dry as usual and I have a 1H in the display. What should I do?
    President:
  • 3,074 Answers
1H= 1 hour delay. press the cancel button and then run the dryer with the vent tube off as if it is not drying like it use to then the vent is restricted, note this has nothing to do with the 1H. You will need to clean the vent tube out and you may want to clean the dryer out,also. You will be amazed how much lint is inside the dryer. Good Luck Tim
Posted on Apr 03, 2011
Sensor Dry off is displayed and clothes are not drying
That would be the dampness sensor probably under the door of the dryer. It tells the machine when things are actually dry. It may have failed. Check the chassis for schematic if you have opened it up, if not look for a manual. Make, model, manual, .pdf on the www.
Oct 14, 2015 | GE Profile Harmony DPGT750GC Gas Dryer
How do I find the moisture sensor in my GE dryer model number DBSR463EDWW?
open door and use flashlight look right at back wall , see those two chrome strips there , thats it!! use glass cleaner on them only , it wont stick inside and stink up your clothes from heating it
Mar 07, 2015 | GE DBSR453EBWW Electric Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 06, 2009 | GE Dryers
What does display code 1H on GE Profile dryer mean?
It means you have it set for a 1 (one) hour delay start
Nov 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
253 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
