None of my turn signals work on my jeep,when i turn my lights on the front right signal stays on
  • 3,083 Answers
First thing to chek is all the bulbs- ohm them out to make sure they're good. If all of them are good, the turn signal switch is inside the steering column, and it will have to be accessed to see what the problem is. It's probably broken, and stuck in a shorted position, but the problem will have to be troubleshot. It's not an easy job getting the steering wheel apart unless you've done it before, and things can fly all over when you loosen the main nut. There could also be some pinched, shorted wiring, or a bad processor control, or a faulty fuse box, or any combination, at the worst case.
Chances are it's the switch , but it's strange that it isn't flashing, and you'll just have to grab a voltmeter/ohmmeter and check out the voltages, and make sure you don't have any broken grounds.
I can't remember too many particulars about replacing the switch since it was years ago, but I remember it was a difficult task, being the first time.
Good luck, and hope this helps.
Posted on Apr 03, 2011
Brake light and right turn signal come on at same time
You put in the wrong bulb and it's feeding back.
Feb 02, 2018 | 2003 Jeep Liberty
My turn signals on my 1988 Jeep Comanche dont work.
My first guess would have been the turn signal switch, which you said you replaced.
You'll have to get a wiring diagram of the switch and start testing wires for power out of the switch. Could be a problem with the main harness going back to the rear of the truck, or a ground for those sockets.
Oct 12, 2012 | 1988 Jeep Comanche
1995 jeep wrangler electrical issue (ground?)
Sounds like your turn signal switch is faulty. Did someone work on your turn signals, try to fix something, didn't know what they were doing? Was the steering wheel pulled off for any reason? May be crossed wires under steering wheel
Mar 06, 2018 | Jeep Cars & Trucks
Need help with re wiring the right turn signal in the rear of the jeep. The turn signal is wired to the front turn signal and doesn't work. The right front works when you turn it on but the right rear...
I'm more interested in why you're having to do this in the first place. Does your right brake light work?
I would check the original wire for that light (I'm assuming cut) and see if you are getting a signal through the original wire supplying the turn signal. It's possible the socket has the issue.
Just a thought... hope it helps a little.
Oct 15, 2009 | 1993 Jeep Grand Cherokee
Jeep Wrangler 2006-Front turn signal/yellow light doesn't work.
Check the ground wires at the lights are clean and tight.Its a ground problem you have.
Aug 08, 2009 | 2006 Jeep Wrangler
Jeep - right turnsignal won't flash
Probably a bad ground on your front right signal, or a bad bulb. Try switching the right with the left, and see if the problem stays in the same place, or goes with the bulb.
May 18, 2009 | 1993 Jeep Wrangler
Jeep88
try making sure all the grounds are good
Oct 06, 2008 | 1988 Jeep Comanche
1998 wrangler turn signal/brake light short
your socket may not be grounded properly, I have seen this before, and the simplest way to fix is change the socket with a new one.Not another used one it may also be bad.
Jul 30, 2008 | 1988 Jeep Wrangler
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
