Question about Kenmore 96562 Dryer
Dryer runs at close of door with pushing start button/now dryer has stopped all together
  • perkins_kenn Apr 03, 2011
    the dryer is loaded with clothes turn the heating switch to desired setting / close door dryer starts to tumble after repeatly doing this the dryer stops working altogether. This is a Kenmore dryer 96565210 65652 serial no ME1503420
  • Kenmore Master
  • 2,605 Answers
Hello Kenn,
Welcome to FixYa.
When you say "pushing start button/now dryer has stopped all together" does this mean there is no sound or movement at all ?
Also if you can confirm it is indeed a Kenmore and provide the entire model number that would be a great benefit to determining what may be at fault as opposed to generalizing about "dryers" ( they can be quite different ) and speaking directly to your machine.
Let me know and we can go from there. I will watch for your post.
Regards,
Macmarkus :)
Posted on Apr 03, 2011
  • Mark MacDonald
    Mark MacDonald Apr 03, 2011
    Hello again,
    Thank you for the reply and providing the model number.
    When you say "after repeatedly doing this the dryer stops working altogether", are you indicating...
    1) the unit won't remain running so you attempt to start it many times over ?
    or
    2) do you mean after several loads in succession it stops altogether ?
    It sounds to me as the start switch is stuck in the start/ "closed" position, if it is indeed starting automatically upon closing the door and you'll need a new start switch.
    If you have an ohm meter you can check the switch to confirm or dismiss if it is faulty. If you're not sure how I'll guide you.
    Let me know if these are the symptoms or which scenario is truth, 1 or 2...or both and we can from there. Hope you can bair with the questions, it is necessary when trying to diagnose from afar.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again,
    Just to follow up on your dryer problem. I alluded to the start sw. being a possible culprit.
    Here's a link that may be of help to you in checking the switch as well as purchasing a new one should you require it.
    http://www.repairclinic.com/PartDetail/S...
    Once again, good luck and please keep me posted on your progress.
    Regards,
    Macmarkus :)
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Our Whirlpool Model LEQ9858PWO just stopped working. It sounds like the function timer might be running and the start button has it's first click when pushed. With the dryer door open and holding the...
The problem is usually caused by a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Dec 29, 2010 | Dryers
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
42 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
