Question about Westinghouse Dishwashers
My Westinghouse virtuoso dishwasher is flashing code i30. Why can I reset? Please help!
heatman101
  • 43501 Answers
SOURCE: My westinghouse virtuoso sensor wash
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Sep 24, 2010
SOURCE: AEG dishwasher 80850 code i30 reset
empty it, tip it on its back, mop up the spilt water, reload it and all should be ok. it is a recurring fault on our machine very irritating
Posted on Jul 30, 2008
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
SOURCE: Westinghouse dishwasher virtuoso SB 925
obuggerit was spot on. Found the same dry joint on the control board relay output. Saved at least $200, but you need basic electronics skills to fix it. Thanks, Dan
Posted on Oct 27, 2009
  • 174 Answers
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
Posted on Jul 22, 2010
Error code i30 (leak). How to fix it?
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Dec 13, 2015 | Electrolux Dishwashers
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Frigidaire dishwasher fault code i30
Good Afternoon Friend,
I understand that you are receiving an i30 error code on your Frigidaire dishwasher. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start your dishwasher. If this does not correct the i30 error code, I suggest you contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Dishwashers
Westinghouse dishwasher error code i30
Not familiar with this particular model but the indication is for water in the very bottom of your unit. Either due to a leak or a faulty switch. A quick leak check is to tip your unit to the side and see if water dribbles out of the bottom. Side needs to come off and either find and fix the leak or replace the switch itself. If its just a leak and you tip the water out it will actually work till the leak fills up again.
Jul 08, 2013 | Westinghouse Dishwashers
Is it easy to get to the circuit board and how on the Westinghouse Virtuoso dishwashers?
Please mention the nature of the fault seen on the machine. It is possible that a failure of the main circuit board means that in most case the board had to be replaced as there is very little that be done for component replacement except if the damage is clearly visible.
Jan 02, 2013 | Dishwashers
Hi My westinghouse virtuoso does not heat the water any more and i wan to know were is the heating element located please
if you want to see all the parts you can go to searsdirectparts.com and put in your model # and you can view every part and location of your machine.let me know if this helps.
Mar 06, 2010 | Dishwashers
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Dishwashers Logo
320 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
