Question about D-Link Web Smart DES-1226G (DNHDES1226G)
Dose layer2 switch DES 1226g,DES 3010g works with ipv6
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Can i plug my exisiting (QT:6) Layer 2 Network switch, will Linksys SRW2024 support for this case
As the basic functionality of both the device is Layer2 switching then both should work.
Nov 04, 2010 | Linksys SRW2024 24-Port Gigabit Ethernet...
Only 8 port working . why other ports are not working?
You haven't supplied any detail on exactly what "not working" means. If you get lights when you plug something in but nothing can connect, it may have features such as Vlan enabled. Can you get to the administration console to reset to factory defaults? Otherwise google to find the user manual and perform a factory reset. Here is one link I found:
ftp://ftp.dlink.biz/des/@archive/des.../des-1016r_manual_v.02.pdf
Oct 26, 2010 | D-Link DES 1024R Plus (DES-1024R+/5)...
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Some ports not working
Since this is a non-managed layer2 switch, it sounds like those ports are dead. Switch ports die sometimes. If you're the original owner of the switch, you may be able to get it replaced under warranty. D-Link provides a 5 year warranty on this switch. Once a port dies on a switch like this one, there's nothing you can do but replace the switch, or just not use those ports. Good luck.
Jul 18, 2009 | D-Link DES-1024D Express EtherNetwork...
D-Link Switch
well in your case, somethings wrong with your switch, because it doesnt work in a full scale operation, it will just work for 20 mins, well, theres no existing kind of performance like that.
you better replace that one with another brand. well, you try to use 3com or CISCO, well you could use linksys, its from CISCO but catering the small business side.
Mar 13, 2008 | Computers & Internet
DES-1005 in HUB working mode?
Unfortunately, the DES-1005 can not be configured to behave as hub and send all the packets to your analyzer software.
Do you have a manageable switch available. Most manageable switches have a "port mirroring" or "monitor" function that allows you to copy all the traffic passing through one port to another port...where the wireshark can receive it for analysis.
Jan 20, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link Web Smart DES-1226G (DNHDES1226G) Logo
29 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
