Question about Maytag Dryers
It makes a sqeaking sound only on heat - Maytag Dryers
    President:
  • 3,074 Answers
Http://www.ehow.com/how_4829560_fix-squeaking-maytag-dryer.html
Posted on Apr 03, 2011
Sqeaking sound when i start in the morning
have you tightend it enough so there is not a lot of play in it if so its probably one of the pully bearings or the alternator bearings going i would check these first hope this helps ivan ps check power steering fluid levels as well as when the resivior is empty they make a squicking noise
Oct 05, 2012 | 2001 Lincoln Continental
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Dec 23, 2009 | Kitchen Appliances - Others
Front end sqeaks on my 2004 vtx honda 1300
Sounds like the brake pads and possibly the brake caliper.
Jun 11, 2009 | 2004 Honda VTX 1300
Drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Sqeaking dryer
Find a heat resistant grease. It must say heat resistant. Then you will need snap ring pliers. The rollers are behind the drum, the whole machine must be taken apart, no fun. While apart, vacuum everything. Note how the belt goes before you take it off. A few extra screws while you're in there will expose the fan area. You will be suprised what you can find there.
Apr 02, 2009 | Maytag PYE2300AY Electric Dryer
I hear a sound like the fan belt sqeaking, I know there is only one belt and that belt is still on . first it made a sound like a tire was leaking air then i heard the sqeaking under the hood
belts can still sqeak even though they are still on, check the condition of the belt, is it craked?, glazed? spray some silicon spray on it while its running and see if it goes away. the belt driven accesories can also make noise, alternator, steering pump, water pump, idler, tensioner, a/c compressor. use a long screwdriver like a stethescope and see if one belt driven acessory makes more noise than the others, just be careful of moving parts.
Mar 16, 2009 | 2001 Ford F150 Styleside SuperCrew
Squeaking noise from front end in cold weather
Bad ball joints. check out front end and make sure nothing else is bad. Good lucka nd thanks for using FIX YA
Mar 03, 2009 | 2002 Oldsmobile Intrigue
When drying the dryer makes a very load sqeaking sound always
check the spindle or axle the drum rotates on. They can be oiled at the pivoting point or turning point. The motor may also be oiled at the axle. You have something grinding in there. Probably metal to metal. Graphite works best as it does not dissipate with heat.
Dec 25, 2008 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
