Question about HP LaserJet 1022 Printer
Paper pulling at an angle
I printed some labels recently, and a few of the got stuck in the printer. I can see one, but I can't reach it or figure out how to get to it. The printer is still working, but it is pulling the paper at an angel. As it is pulling it through the printer, it is turning and tearing the page.
Unfortunately, I don't know the anatomy of a printer very well to explain where the label is. It is under the toner cartridge behind the bar (towards the back for the printer) that seems to be moving the paper in the printer. If I could move the bar slightly, I could get to the sticker to remove it.
Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
I not sure of which bar you are talking but,try getting a pair of long nose pliers that are curved at the endand see if you can get to it that way?
Posted on Aug 08, 2008
  • CheckitRight
    CheckitRight Aug 08, 2008
    does the bar have rubber roller in it? if yes it is the pick up tire that pulls the paper into the machine.
    make a copy then stop it as the paper goes through remove toner and paper, is the label in a different position? you may have to do it several times before you can get an angle that is ok for you.
Manual feed won't grab paper
If the printer works good when it prints the envelopes/label one by one, I think it works normal (because the paper is not a standard paper).
Mar 06, 2014 | HP Office Equipment & Supplies
Address label possibly stuck in printer
turn off the lights and close door in your office..use a pen light to look inside for a white reflection..let me know if that yields anything..
Oct 13, 2008 | Epson AcuLaser C900 Printer
I pulled paper out but I have bits of paper still stuck and cannot reach them. How do I get it out? They are way in the back.
Most printers have a flap at the back which you can open to get at damaged paper - it's not always obvious what to do, but an HP printer has a knob which you twist and the cover comes away.
I suggest a pair of fairly long tweezers is helpful to pull out bits
Feb 25, 2014 | Brother HL 2270DW Laser Printer
Paper gets stuck in Epson S/C 900. Laptop XP reinstalled. I will pay the $30 if you can get it to work. Drivers installed by Epson. Cisco says it isnt them. Dell too. Printer on for a year but not used....
inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper
you can also you a light blower or vaccum to clean the printer be sure to remove the ink catridge from the printer before using them
after doing so click the printer icon in the task bar and click open it and delete all the files in them
then click start settings click printer and faxes then make your printer default then switch of the printer and the computer remove the power plug and the usb cable wait for few minutes and replug them then restart your computer and the printer then click start setting printer and right click the printer and click properties in the printer properties click the print a test page and your printer will be ready to print
Apr 20, 2011 | Epson Office Equipment & Supplies
Printer will not print...it jammed ......the paper jammed in the machine..and I pulled it out....
1. Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
2. Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
3. If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
4. Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.f you have a laser printermag-glass_10x10.gif, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
5. if you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available atelectronics shops or drugstore.Try changing the toner or ink cartridge.
Feb 04, 2010 | HP Office Equipment & Supplies
Why does my dell 1720dn print crooked?
The paper feed rollers are dirty and are pulling the paper in at an angle.
Could be from high % cotton paper or sticky label printing.
Clean the "pickup" rollers with eyeglass cleaner (not Windex).
Nov 06, 2009 | Dell 1720dn Laser Printer
Sticker label stuck inside
Depends on where inside the machine the label got stuck. There's covers on the back, front (which also lets you remove the toner/drum unit for more access) and also the paper tray.
If you're unable to reach the label removing these parts/opening the covers, the machine would require to be screwed apart to reach it. There is no levels to release pressure on drum or similar to reach further within, unfortunately.
Jun 02, 2009 | Brother HL-2040 Laser Printer
When going to print paper is pulled in angled and jams thanks
i do not know the model of the printer that you have, but the most common problem is that you have something stuck in the area where the paper is not being pulled in. You might have a small piece of paper jammed in there or some foreign object. It is also possible your sensor is jammed and the paper is hitting it.
Lastly, if you have 2 pickup rollers (depends on the printer that you have), one could be worn out.
thanks adi
May 07, 2009 | Office Equipment & Supplies
Label paper will no longer feed
Most likely some of the gum (or even part of a label) has stuck to the inside of the paper feed mech. It all depends on where it is. You could try giving the inside of the feed hopper a good scrub with alcohol wipes or similar, reaching in with your fingers or using a wooden stick. I have successfully used this method on this same issue several times in the past.
Apr 12, 2009 | Epson Stylus Photo R200 InkJet Printer
Lexmark T630
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Feb 27, 2008 | Lexmark T630 Laser Printer
HP LaserJet 1022 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
