Question about Nintendo GameCube Console
My wii will not read pikmin 2. I have tried with 2 disks what should zI do
    President:
  • 894 Answers
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
Posted on Aug 18, 2011
What's your problem?the wiw has trouble reading the disk
Your WII is having trouble reading disks? Try using a dvd/cd ROM cleaner disk. Run the cleaning disk in the WII a couple of times and try inserting your game again. If it still does not read the disk, try cleaning the game disk itself with a lint free cloth and alcohol. make sure to dry the disk completely and never wipe in a circle. If this does not solve the issue, try playing the disk in another WII to figure out if the problem is isolated to the disk itself. If the disk plays in another WII, then contact the manufacturer and send the console in for repair.
Oct 09, 2011 | Nintendo Wii Console
Nintendo wii message reads: error occured remove disc turn off console check operations manual for information! on 2 new games
Some older Wii units also have trouble with Dual Layer Discs, which pack more info onto a disk like Super Smash Bros. Brawl and Metroid Prime. If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. the other resolution for this is to change the laser on the system but it will cost you for that. Try to clean the lens first it might read the new disk.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo Wii Console
My wii fit plus disc reads cant be read when inserted in to the wii help please can it be fixed
Hi lyned1,
If the Wii is having trouble with a disk, it means there's either a problem with the disk or the Wii. If your Wii can't read any disks then you'll want to contact Nintendo. Otherwise you need to investigate your disk.
If you hold the bottom side of the disk to the light you should be able to see if there's a smudge or scratch. If it's a smudge, cleaning the disk will often fix the problem. Use the microfiber cloths used to clean eyeglasses or, short of that, a tissue. Just rub the smudged spot. (When using a tissue I generally steam up the spot with my breath first.) If the disk looks good, put it back into the Wii and see what happens.
A scratch is more problematic. If it's a game you just bought, try exchanging it where you bought it. Otherwise you can try polishing out the scratch.
Some older Wii units also have trouble with dual layer discs, If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. And also you can try to use a different disk to check if your system will be able to read it. then try the Wii Fit Plus If after all that, your Wii still can't read the disc, it's probably just a bad disc.
Jan 28, 2011 | Video Game Consoles & Games
Reads the wii fit disk and when i push start it reads game disk could not be read . refer to the wii operation manual
Hi there rina hz5
What to do when your Wii Has problems with reading disks and you have tried cleaning the disk.
This does not mean your Disk Drive needs replacing more often than not it just needs the laser to be readjusted.
Option 1
You can send this off to Nintendo if your still in warranty because it is included in there free fixes so they will do the collecting for you, fix it and return the Wii to you, all for free, but it will take 4-6 weeks.
Option 2
If you are out of warranty its the same process as above but its $150 in cost
Option 3
now a new Disk drive would cost around $75 for a compatible one and you may need some one to fit it at a cost as well.
Option 4
What I recommend is a Wii Repair Guide that will show you the simple steps yourself, you will be up and running again in less than an hour and the cost is far less than option 2 & 3
Good Luck
WiiRestore
Feel Free to leave me a comment if you need further assistance.
Dec 24, 2010 | Nintendo Wii Console
Wont read disc and disk is clean with no scratches
If your Wii won't read any discs, even though the discs are clean, I have 2 solutions.
Visit support.nintendo.com
Or call 1-800-255-3700 for Wii assistance.
Jun 05, 2010 | Nintendo Wii Console
Wii disk wont spin any disks
Hi there jus4
Option 1
Option 2
Option 3
Option 4
Good Luck
Chris Foley
Dec 11, 2009 | Nintendo Wii Console
Wii will no longer read wii disk and tried different wii disk.
try unplugging it for at least 5 minutes and then plug back in and retry.
Jun 03, 2009 | Nintendo Wii Console
Unable to read disk for Mariocart
try to update your wii to the latest version...
Jun 03, 2008 | Nintendo Wii Console
My wii remote It doesn't work
have you tried pressing the sync button in this order
1. the red sync button on the console
2. the red sync button on the Wii Remote
Jan 25, 2008 | Nintendo Wii Console
Nintendo GameCube Console Logo
104 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
