I Have a LG WF-T1391TP Turbo Drum washing maschine.Everything works but it does not spin.If I remove the back cover and shake the drum housing around it sometimes spin but I think it does not pump the water eitgher.
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
scottowa
  • 87 Answers
SOURCE: how to take apart drum assembly on kenmore front load washer
Is this a HE2,5,4 model? Can you give me the model number from inside the door. If it's a front loader. The only way you can get it out is to totally tare it down, cement, springs, shocks, and crack apart the outer tub. Very very labor intense. Usually if the unit is out of warranty, the cost of a tech to do it isn't worth it. What's the issure with it?
Posted on Jan 24, 2009
SOURCE: LG front load washer A coin fell in between
Hi Echucaellect,
Thanks for the insight. I have a Samsung front loader washer, and have the same problem. Can you tell me how I can fix and retreave the quarter/coin?
Thanks,
Posted on Sep 14, 2009
  • 234 Answers
SOURCE: loud knocking noice around drum area when on final spin.
This is not an unusual problem for washers, but how to eliminate or reduce it would help to know what brand and model. Sometimes it is the balance ring that sits atop the inner drum, or it could be the antivibrate friction pads that are too worn (they are diffierent on each brand), or could be the balance springs at the bottom of the tub assembly ( there are 3 or 4 springs and one could be broke), or could be the balance (suspension) cables that appear in some brands and the cables or pulley wheels are not in line or are worn/broke.
Goodluck, Macgivor
Posted on Oct 14, 2009
Testimonial: "hi its a creda 1200 excel 1200 w220vw"
SOURCE: drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Posted on Nov 22, 2009
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
Jan 11, 2018 | LG Washing Machines
My top loader lg WF 8071TTP turbo drum does not drain and spin
Drain pump may be defective or something is obstructing it.
Nov 01, 2017 | LG Washing Machines
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
I have a lg top loader washing machine model:wf-t1391tp when wasing and rinsing it makes a huge grinding and crackling sound like is going to brake something underneath motor or gearbox.
Check whether the inner rotating drum is contacting the stationary tub.
The other problems that cause this condition is the clutch assembly and or the motor drive system.
Check both assemblies for security and free movement of rotating parts.
Check also the tub supporting dampers for condition.
Feb 23, 2016 | LG Washing Machines
A great deal of fluff is appearing on the washed clothes. The machine is an LG WF-T1391TP top loader, 15kg.
If you told us the make and model of the machine maybe someone could help?
Aug 12, 2015 | Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
