Question about Bushnell Banner Dusk & Dawn 3-9x40 Riflescope
My crosshairs have rotated yet the scope itself has not moved in its mounting. Is there an adjustment that allows me to rotate them back, or does this mean the scope is defective
    Problem Solver:
  • 5 Answers
You best bet is to contact Bushnell. There is no adjustment since the reticule is fixed inside the tube. The reticule should not be moving so this is a defect in your scope.
This is the Bushnell site for repairs and customer service. Contact them and explain your situation.
Posted on Apr 05, 2011
My elevaition crosshair wont raise high enough to raise my point of impact
your crosshair actually needs to go lower to raise the point of impact. if thats what you meant than you have a mounting/scope problem. the scope should naturally align within the adjustment range assuming the mounts are correct and the scope is functioning and mounted properly.
Sep 29, 2013 | Barska Optics Optics
Cannot set wind age and elevation on a Nikon pro staff riflescope (not enough adjustment )
Check you mounts. If mounted properly you should have enough. if they are not moving at all you have prob broken the fine wires that form the crosshairs.
Jan 07, 2013 | Nikon 3-9x50 Prostaff Riflescope In Matte...
I cant site the scope in the adjustment ot make it go left to right will not adjust
Put the gun in a vise. Look into a mirror and align the crosshairs so that you have one set of crosshairs when viewing in the mirror. The windage adjustment is maxed to the side you are trying to adjust . This will set the parallax of the crosshairs close to zero and allow adjustment in all directions.
Dec 30, 2010 | Leapers Optics
Hi, just bought a Hawke Varmint II 4-16x44 AO. I started searching for the zero point, before I mounted it on the rifle Itself. Because I wanted to make a bigger adjustments from the mounts when bore...
The Hawke comes with a good, lifetime warranty.
They are reported to be fast and fair about these things.
The best thing you can do is send it back and they will fix it or replace it.
Oct 30, 2010 | Hawke Sport Optics Hawke HK3232 Varmint II...
Crosshairs not verticle/horizontal
Not sure what you mean, but if your scope is not mounted right the cross hairs will be off hor/vert. You can loosen the scope mounts and rotate the scope till the look right to you. You will have to re sight.
Nov 26, 2009 | Optics
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Crosshairs moved after rifle was sighted in
now then,,,did the crosshairs move or did the scope slip back out of line? if the mounts were not tight then its likley to be the scope slipping back but if the crosshairs moved were they just setteling or are they moving,,if there realy moving the scope is claped out or shook apart inside,,,how big is your rifle you put this scope on? 357mag??? i have a simmons scope on a 7.62 and on a .303 enfield rifle its ok on them?
Nov 02, 2009 | Simmons Optics
Crosshairs on pentax 4.5x14x42 don't move
With modern rifle scopes the crosshairs do not move.They are designed so that the crosshairs are always centered.I have not seen a scope with crosshairs that move for about 40 years.If your scope has 1/4 minute clicks, then the strike of the bullet moves 1/4 inch at 100 yards for every click.1 inch for 4 clicks and so on.If you rifle shoots 6 inches high at 100 yards you should turn it down 24 clicks to strike dead on.Many hunters and shooters adjust their scopes to strike 1 1/2 inches high at 100 yards.Then it will be accurate to about 300 yards without further adjustment.
Feb 15, 2009 | Pentax 4.5X-14X 42mm Pioneer Matte Rifle...
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Bushnell Banner Dusk & Dawn 3-9x40 Riflescope Logo
1,083 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
