The bearings on this rotor are pressed into the rotor, All rotors for this year come with new bearings already to go, But beware cheap rotors have cheap bearings I have seen high failure rates almost 90 % The other guy answered , with out of date info even some of the parts house guys don't know there stuff, you don't use your old bearings they are not grease able and there is no grease seals The nut has stamped in it to not reuse they are available after market for a price,, 2 wheel drive trucks have press fit bearings in the rotors 4 wheel drive trucks have a floating rotor with a separate hub bearing assembly
Hi, if you have the right socket in a half inch drive with a breaker bar, you can get it off. Cheat if you have to. The new hub will probably not have bearings, so you will reuse yours with a little new grease. I don't think there is any kind of dust seal. There should be a large washer on the outside just under the axle nut. The final torque isn't critical. You can use your weight multiplied by the length of the breaker bar to estimate. I recommend you replace the pads on the other side too, since they come in sets anyway. Please let me know if you have more questions, and thanks for using FixYa.
