Question about Bose Lifestyle 48 System
Hi my Bose system keeps on shutting off about every minute and then says Bose lifestyle and then failed 802 call Bose as soon as that saying goes from the screen i can turn it back on...therefore it shuts off says failed 802 and then i can turn it back on again in about the next ten seconds.....why is it doing this? Please help asap. Thank you.
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: life style error codes 801 & 802
Unfortunately my Lifestyle is dead after getting these errors!
Bose will fix it - replace it if necessary - but at a cost!!!
Posted on Mar 18, 2008
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
Failed 802
The HDD is bad and need to be replaced.
Nov 24, 2013 | Bose Lifestyle 38 System
FAILED 802 CALL BOSSE
I have the same problem since the Earthquake in Christchurch NZ.. Called Bose support centre and it seems the hard drive has failed and will need replacing, so all stored music etc lost. Cost to fix is roughly the same as getting a new media centre (DVD/CD) component. We are getting a new one through our insurance, apparently Bose Lifestyle's do not like being shaken around a lot or dropped.
Normally accompanied by a screetching sort of sound when you try to access stored music or turn the unit off.
May 08, 2011 | Bose Lifestyle 48 System
My bose was playing stored music and then for no reason it has stopped. can play cds ok
My bose stereo system plays a cd for a few minutes then stops, what is this, and it says failed code, call Bose. How do I fix this.
Aug 01, 2009 | Bose Lifestyle 48 System
Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Jul 10, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
System keeps shutting down
Hi, I have not been able to fix the problem myself !! : ( I am taking it to the place I bought it from as I am still under warranty. Will let you know what they come up with when I get it back. Regards jessiedog
Jul 08, 2008 | Bose Lifestyle 28 System
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
187 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
