Question about Kenmore Microwave Ovens
Constant beeping, can't turn it off, with F11 error
  • 3,530 Answers
Welcome to Fixya
Check the 2 house breakers for the oven are both on. If one is tripped it will light up but not run. If both switches are not tripped. Then turn the both breaker switches off for 10 seconds and then on. And try the oven. If it still does not work then mostly it is a bad EOC (Electronic Oven Control). Quite expensive part, you might want to have a hands on tech on location to test it before you spend the money on that part. Thank you for using Fixya!
Posted on Apr 03, 2011
Error code 5E
Take the battery out for a bit.
Jun 01, 2015 | Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
CONSTANT BEEPING WHICH WON'T QUIT
This sounds like a short in the keypad control, you will need a professional to assess the situation.
Mar 26, 2012 | Amana Microwave Ovens
My whilrpool stove goes in fse1 error mode and beeps constantly. even after i push cancel, it seems to reset then goes back to beeping after a few minutes without even being touched. I unplugged, reset and...
Hello jerseydev594,
You might want to visit the Product Owner Center on WhirlPool's website, which is: http://www.whirlpool.com/owner_center
My guess is that your WhirlPool stove might be malfunctioning so you might need a replacement unit if possible, Again, http://www.whirlpool.com/owner_center can help you.
Sincerely, oliver18754
Jul 08, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
The camera is not turning on. The lens is out when it should be inside when its turned off. It keeps beeping when i try to turn it on but it will not switch on.. constantly beeping.
Sounds like you've got a lens error and the beeps are signaling your lens is stuck. With the camera laying on its back, try tapping the lens ring while pressing the start button. You may just luck out. It's about all you can do without taking your camera apart.
Dec 11, 2009 | Microwave Ovens
Ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 17, 2009 | GE JVM1430 Microwave Oven
I keep getting an f1 message and constant beeping from my oven
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 30, 2009 | GE JVM1651 Microwave Oven
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
