Question about Kenmore 53701 Dehumidifier
On My Model # 580.53701, the compressor runs & will freeze up the coil! But the fan will not come on, either high or low speed. Do I need to replace the fan unit assembly or the fan resistor switch?
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Apr 23, 2011
Fan always runs, speed doesnt change (low/high), setting humidity level doesnt impact...is this a control board or circuit board issue?
Verify the humidity reading with another device. Perhaps the humidity sensor is dirty or bad.
Another possibility is the switching device that runs the compressor and fan is shorted. If it's a mechanical relay, the contacts may have welded together, or if it's a solid-state relay, it's got a punch-through or meltdown in a device junction. My guess is it's a mechanical relay since you mention it used to click on and off and now you don't hear that. The relay may be on the control board, or it may be mounted separately - I don't have a photo or diagram of the inside of your model available.
Jun 25, 2015 | Dehumidifiers
Whirlpool Basement Dehumidifer is freezing up about l/3 from the bottom. Compressor will not turn off. Coils were cleaned and cleaned fan is running freely. Sitting in well ventilated area and temp...
IIt may very well be that the the air intake filter needs to be removed and cleaned. But, before doing this, turn the unit OFF & unplug it. Allow the unit to completely thaw, before removing the filter.Never operate the unit without the filter in place, As this could damage the unit.
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Coils freeze up. completely blocked. have to shut off to thaw coils. located in basement.
After the unit is totally thawed and dried, turn the unit Off if you haven't already and unplug it. Remove the filter and clean it. If it's really dirty wash it with warm water and dish washing liquid, thoroughly rinse it and allow it to completely dry, before reinstalling. DO NOT operate the unit without the filter in place.
Because the air temperature in a basement is colder at floor level, than at shoulder level, this caused the coils to freeze. Dehumidifiers do not work well at temperatures at or below 60 degrees F. That is, unless, it's a Low Temperature model, designed especially for basement applications. Obviously, yours isn't a Low Temp model.
To overcome this, place the unit up on a sturdy table, counter top, etc, that can handle the weight of the unit, as well as a full bucket of water. The higher off the floor the better. This way, the ambient operational temperature will be higher and the coils will have less of chance to freeze again.
I would suggest that continue to monitor the unit and if you notice that it's doing more than a little frosting on the coils, turn the unit OFF immediately. A little frosting is normal and the deforst mode should kick in and thaw the coils. When this happens, the compressor should automatically shut OFF, but the fan will continue to run. Once it's defrosted, the compressor will start again, if necessary.
I hope this helped you to troubleshoot and solve the problem. Please let me know.
Jul 19, 2011 | Whirlpool AD50DSL Dehumidifier
The dehumidifier does not collect any water, the fan is running and I can hear the compressor kick on and briefly run 10-15 seconds, The fan runs continuously.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled model, set the humidity extraction level on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem.
Jul 08, 2011 | Maytag M7DH45B2A Dehumidifier
DEHUMIDIFER COILS FREEZE OVER, WHETHER MACHINE IS RUNNIG ON LOW OR HIGH. FILTERS ARE ALL CLEAN.
Turn the Master ON/OFF Switch to OFF, unplug the unit and allow it to thaw out completely. You may want to put some old towels under it, to absorb the dripping water. Once it has completely thawed, remove the bucket, the air intake filter and the face of the cabinet. You should now have access to the coils. Clean them with a mild soap and warm water. Rinse and thoroughly dry the coils. Once they are totally dry, spray a very light film of WD40 on the coils and then wipe off any over spray. Reinstall all the remove parts and test the unit.
Keep in mind, if you are using the dehumidifier in a basement, the air temperature at floor level is colder than at chest level. Dehumidifiers don't work well between 40 & 60 degrees F. (Unless, they are a low temp unit). Any lower, the coils will freeze. Raise the unit up off the floor onto a sturdy table or counter top, that can hold the weight of the unit plus, a full tank of water. In a basement application, doing usually solves the problem of freezing coils.
If after doing all the above, the coils still freeze during operation, the compressor may below on freon and needs to be recharged. Or the defrost sensor on the unit, needs to be replaced.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 08, 2011 | LG Dehumidifiers
Santa fe dehumidifier running but not producing any condensate. No ice forming on the coils and filter is clean.
You should check if the compressor is running. Your description makes it appear that the fan may be running and the compressor may not be running.
There are many things that can cause a compressor to cease running:
Open defrost thermostat
Bad run capacitor
Low refrigerant charge (caused by refrigerant leak)
Bad compressor relay
Bad compressor overload
Bad compressor motor
Other things to check:
If the fan switch is set to "on" and the humidity control is set to a high humidity level, the unit may appear to be running, but the compressor will not operate. Check the setting of your humidity control.
If the dehumidifier is operating in a room with a high temperature and a low dew point (very low relative humidity), it may be unable to remove any more moisture from the air.
If you are not comfortable troubleshooting the unit on your own, call the manufacturer service department at 1-800-533-7533, EXT 8459. They are very helpful.
Mar 05, 2011 | Santa Fe 4027450 Dehumidifier
Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
May 10, 2009 | Frigidaire FDL50R1 Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
Dehumidifier freezing and failing to drain
I have a model M7DH65B2A that had the same problem.  The metal clip that holds the frost sensor to the evaporator coil had rusted clear through and the sensor was hanging in midair.  Not knowing whether I could get a replacement, I re-attached the sensor securely to 2 of the loops of the coil with nylon ties and a bit of thermal heat sink compound, available at many electronics specialty stores.  Problem solved.  You may want to get the correct parts to repair your unit, but I chose to go this route because my repair will never rust through.
Jul 24, 2008 | Maytag M7DH45B2A Dehumidifier
A7dh65b2a
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Dec 07, 2006 | Fedders A3DH30B2A Dehumidifier
Kenmore 53701 Dehumidifier Logo
200 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
