Question about Canon PC-795 Copier
No paper jam and no copies
The paper jam icon (figure 8 with zig zag) never goes away. I put a brand new toner cart in. Still no copies. Absolutely no paper is jammed. Help! Any ideas. I'm ready to replace it, but I'd like to get the use out of the cartridge and then put it on the street.
Thanks.
Jed
    Scholar:
  • 62 Answers
Check the fixing ***'y
Posted on Jan 24, 2009
How to figure square inches
Imagine you have a stack of pieces of paper or cloth that are one inch square, or 1" X 1".
Then, whatever you wish to convert, just multiple the length times the width.
For example, a piece of paper 8" X 11".
8 X 11 = 88.
Hence, you have 88 square inches of paper.
Mar 15, 2016 | Kenmore Vintage Sewing Craft Quilting...
Zig zag yellow light on
old post. so Il show how to fish.....
alldata dot com. and then.... year, make model.....
but the op guide does answer the question, decode lamp marks to ENGLISH. sure.
http://www.scribd.com/doc/26488620/Grand-Vitara-Owners-Manual
1st google hit, chapter 4.
im not sure what zig zag means. view page actual
i see a car ICON with zig zag, car tracks. That means ESP.
Electronic Stability Program (magic) when magic fails
find a certified ASE mechanic, or go to SUZUKI, dealer.
if the dealer is still open (they are in Chapter 11)
there are no other zig zags, unless you think a KEY icon is that.
you now have the page above, you can read the words there.
they are all 100% correct.
Jan 28, 2013 | 2008 Suzuki Grand Vitara
Machine won't zig zag even though the needle goes from side to side the line of stitching is straight.
put in a new needle
rethread the machine top & bobbin--use every thread guide
make sure the zig zag settings are correct
it's also possible that the machine could have a worn or damaged gear or cam--which would have to be checked at a sewing machine shop
Mar 20, 2012 | Sewing Machines
Canon pc745 not copying. error symbol 8zig zag line. there is no paper jam and just loaded brand new toner. please help
Hi steven640,
That symbol you are getting is for a paper jam. The figure 8 represents the rollers and the zig zag is the crumpled paper. Since you have already checked the machine for any possible paper jam the next thing you can do is to reset the printer. Here's how:
1. Turn the printer OFF, when it is on, by suddenly and sharply unplugging it from the power source.
2. Also unplug it from the computer!
3. Leave it that way for 10 minutes.
4. Plug it back in.
5. Turn it on if it didn't turn itself on. Wait for it to initialize.
6. Try printing again.
Hope this helps.
Thank you for using FixYa.
Sep 05, 2011 | Office Equipment & Supplies
I have a problem when u use copier. there are red icon in triangle. how to fix that.. .plz help me.
Normally the symbols indicated require attention some times a triangle with little dots in the triangle need to have the waste toner emptied from machine hope this helps you it depends what is being shown in the triangle a zig zag with may be two circles in the triangle would be like jammed paper needs to be removed
Feb 25, 2011 | Sharp AR-M205 Copier
Purchased new ink cartridge for my Canonpc940. Lost direction book. I have installed it. It is a little bit loosed. When I turn the copier on a little flashing icon lights up and flashes. The icon...
The figure 8 with a check mark is the paper jam indicator. The machine thinks there is a paper jam somewhere. Just check the whole machine inside and out, including the bottom paper tray. Hopefully you can get the jam reset and make sure the toner is ok. As long as the box that the toner came out of has E20, E31 or E40 you should be fine on the toner.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Canon PC-940 Black and White Copier
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
NEW COPIER AND THERE IS A LIGHT ON AND I AM NOT ABLE TO COPY WITH IT,. TWO CIRCLES W/A ZIG ZAG LINE. AND I DON'T HAVE A MANUAL. ANY HELP WOULD BE GREAT.
I believe that is the Paper Jam light you're referring to.
Those two circles are supposed to be rollers and the zig zag is the jammed paper.
Be sure to check EVERYWHERE for a jam and move the rollers if they will let you.
Oct 13, 2009 | Sharp AL 1631 Copier
PC745 error code - what is it. Source for manual?
that is the symbol for a paper jam. the figure 8 represents the rollers and the zig zag is the crumpled paper.
Dec 27, 2008 | Canon PC-940 Black and White Copier
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Canon PC-795 Copier Logo
148 people viewed this question
old marine
old marine
