Question about Garden
I have clean gas, a new plug, i disassembled and cleaned the carb. but it will not run for more then 10 seconds.
    President:
  • 3,074 Answers
Check the prime bulb as it may have a crack, if it is good then check the two fuel lines that run from the bulb to the tank. Good Luck Tim
Posted on Apr 03, 2011
I have a psa 225 echo weed eater. The engine readily starts but will only rev up using the choke lever back and forth. No power. What's my problem?
Carb or filter
. replace fuel filter in tank while checking both pickup and return fuel lines.
remove carb and disassemble cleaning all parts with carb cleaner and some soft air blow . look for small screen its round and about 1/4 round in carb these are so small that the gas that's available gells and plugs the openings . try to use non-ethonal high octane gas and use echo 2cycle oil .
Jan 26, 2017 | Echo Garden
I have a craftsman 27cc weed trimmer and I cannot get it to stay running.
Carb needs disassembly and complete cleaning and may need new diaphragm as well.
Jul 31, 2016 | Craftsman Garden
Scooter has 40 original miles.New,old gas, I put innew gas. It starts,idles only, if I give it gas it stalls and won't run..
Hi, Rick if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
How to clean carburetor in 15 minutes
Nov 25, 2015 | GAS Motorcycles
Will not start
Hi, Richard if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
Nov 12, 2015 | GAS Motorcycles
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Engine runs for 20 seconds then stops.
I have no clue as to the actual solution, but what I would do is disassemble the carb and clean it out. Had a similar issue with a honda motor; ended up buying a new carb off an auction online for $45. Take lots of pics as you remove stuff or find an online parts catalog with a parts blowout diagram.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Carb problems
Pul the spark plug and inspect for fouling, replace or clean the plug and try again. The next step would be to make sure the carburator is not loose and is tight to the engine, then disconnect the fuel supply to the carb and verify it is getting fuel. This as a place to start your diagnosis, and proceed from there. It may require you to disassemble the carb and clean a blockage, but this is the extreme.
Feb 12, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Craftsman weedwacker model 358.795160 will not start new spark plug new gas 70 psi compression check.Will run sometime for 1 second.Clean carb.gas line getting gas and seams to have a good spark can...
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor again. Make sure the small screen in the carb. is free of debris. You should be able to see daylight through it. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 13, 2009 | Craftsman Garden
Carbed engine stops dead after 10-20 seconds of running.
If it was the ignitor unit (I assume you mean the ECU) it wouldn't start at all.
Did you check the fuel pump and it's relay?If the bike was garaged for 2 years you should recalibrate your carbs.If there was gas in them all that long they need to be cleaned.
Jun 07, 2009 | 1997 Honda CBR 600 F(3)V
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
