Question about ASUS Eee PC 1000HE Netbook
I cant get passed the first screen is says loading os image. con you help?
  • 61 Answers
Sounds as though your harddrive might be virused up...a corrupt registry command preventing it from booting...or your harddrive may be faulty..
Try chk disk command to scan the surface of your harddrive just incase you may have any bad segments...if its all clear,take out your harddrive and virus scan it with another computer...
All else fails...you may have to reformat and try a clean install.....
Posted on Apr 03, 2011
My hp reaches the factory image restor and the gets to 1% and stops says no image
NO PC STATED NO OS STATED, BUT IS 2006 OR NEWER
since you pushed the F11 key to do HP restore right? or from CD's you never say restore medium.
there are only 2 or 3 causes of this, (or the pc is sick)
the HDD is bad.
the HDD was slammed
or the HDD was infected it wrecked the restore paritition
run the HDD TESTS IN BIOS yet.
if that passes then it was slammed. (or infected)
if PC came with XP and someone upgraded to w7 using the fresh load method that kills the original restore dead.
i cant guess what you have, not possible. at all from 1984 to now.
http://www.pcdied.com/slammed.html
if the HDD tests pass.
then the HP install media works
F11 works if and only if the PC was not slammed.
slamming means the C:/HP_recovery partition was wrecked.
via many many ways.
Aug 18, 2017 | HP Computers & Internet
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
Cant get passed automatic repair cycle
Likely a bad battery on motherboard so that instructions for reading memory that instructs machine about hardware and how to bring up the OS.
Oct 11, 2014 | Samsung Computers & Internet
Sylvania Netbook SYNET7WID frozen on OS Image what do I do?
When you turn it on, as soon as the very first screen appears press F11.
Than it should take you straight to factory restore settings. P.S.
This will delete everything it so safe your stuff in Hard drives or flash drives.
hope this helps
Oct 06, 2012 | Sylvania G-Netbook
I cant get my dell to load after turning it on
Does it pass the POST (Power On Self Test)? Does it try to load the Windows OS?
If it pass the POST and cannot load the OS, its most likely that the hard drive is faulty you may have to replace with a new hard drive load a new OS and your applications.
If the OS load and you cannot log in to your Dell desktop, you may have to do a password recovery by entering answer your security question.
Jun 17, 2012 | Dell Inspiron 1545 Notebook
GOT SOUND BUT NO PICTURE ANY TIPS PLEASE INVERTER NOT FAULTY
Good day!!!
That problem is usually cause of bad inverter board or T-con board....
Please do this procedure to determine the problem:
  1. Open the back cover.
  2. Check the input voltage of inverter board.It should have 24vdc
  3. If you don't have 24vdc the problem is on the power supply...Check the possible open resistors that pass through the 24vdc line..
  4. If you have 24vdc and your TV is no back-light...The problem could be on the inverter board..Please replace it to fix your problem..
  5. If you have back-light but no picture on the screen the T-con board is faulty..T-con board is the responsible for processing of video comes from the main board..Please try to replace it if this symptoms appear..Have back-light but no picture or image on the screen.
I hope this solution will be helpful..
If you have any clarification or more query please feel free to ask..Just add a comment to post your query..
Thanks for consulting fixya..
Aug 13, 2011 | Televison & Video
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
IT SAYS LOADING OS IMAGE,,HOW DO I FIX IT
Try restarting you system in "safe mode" and then install Image toolkit.......it works....goodluck!
Jul 29, 2010 | ASUS Eee PC 1000HE Netbook
EPC 7'' Notebook freezing with error message ''loading OS image...''
It is like the problem of hansen4859 here.
Please view the Solution #3 on the page above.
(please click helpful - yes)
Jan 05, 2010 | Computers & Internet
ASUS Eee PC 1000HE Netbook Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
